Pioneer 500 rebuilt again, still burning oil
P
Pax
16
37
North Idaho
My ‘18 pioneer 500 has been a headache. Issue started 2 years ago with dust ingestion from air filter not being on all the way, 600 miles at the time. Had top end rebuilt, blew again within 75 miles. I had a different shop (both non-dealers) replace jug (own) and piston (Nembutal). Went about 75 miles again and crank went out. Had crank replaced, rehoned and rings. Went about 100 miles, still burning oil. Honed and rings again. Mechanic had me put 300 miles on this time, burned oil entire time, getting worse with more miles- oil not on dipstick after 1/2 tank of gas. Had it bored and new top end (this time own). Started burning oil again around 100 miles. Any ideas? He warrantied his work which is great- down side he keeps it 4-5 months every time I drop it off. It’s literally been at my house for about 5 months since fall 2020…..Any thoughts on what the issue could be?
Thanks!
  • Wow
Mopower58
Mopower58
CST is the Best!
71,721
655,612
Crystal Springs,Ms.
Would that make it burn oil? Another piece of info is that crosshatch in jug has been gone after 100 miles each time.
If the crosshatch is gone each time, sounds like the air intake hose is leaking between the air filter and cylinder allowing dust to enter. Dust/dirt will act just like sandpaper on the cylinder wall.
906UP
906UP
13,205
123,458
da Yoop
Would that make it burn oil?....
Yes, the crankcase builds pressure as the piston moves down, vacuum as the piston moves up, if the vent is blocked it will force oil past the rings.
This is the hose, about 3/4" dia that goes from the left rear of the engine up to the air cleaner box
bigshoe
bigshoe
421
1,426
I've screwed up before and done this myself, but he's prob putting rings on wrong they usually run about 100 miles before they give up the ghost. Also honda oe parts or nothin. I make customers sign that I'm not warranty anywork that has ebay or Amazon parts on it
P
Pax
16
37
North Idaho
Thanks a lot, I will check it out
The only reason I don’t think that makes sense in this case is since the last rebuild it has only been driven in spring conditions on pavement and damp Forrest service roads- still a month away from dust season where I live.
P
Pax
16
37
North Idaho
Thanks, this time around it was all OEM, even showed me the packaging. Could be that he’s doing rings wrong but 4 times?
Ohio4x4
Ohio4x4
I brought the dishwasher
1,496
15,042
Whats been done with the head during these rebuilds. Ive had ranchers and foremans wear the valve stems and guides causing bad oil consumption.
P
Pax
16
37
North Idaho
He’s checked valves and replaced valve seals.
