P700 Pioneer 700 with Can-Am Commander Shocks
JailCop
JailCop
Northern NY
Nice work! Are the different colored springs all the same weight? How much would you want for the black ones?
I'm told they're all the same weight rating, but I have no concrete evidence to back that up, either...I let my buddy hang on to the black ones, he wanted to try fabbing them onto his brothers outlander 600, but if that doesn't work out, I'll get them back and contact you, I'll only ask what I paid for the red springs, $50 plus whatever shipping.
Red on red looks sharp!!
Thanks! I thought so too. I was just happy to find a set of commander shocks that weren't yellow lol but I would have dealt with it or tried painting them. It was like fate when I saw the set of red springs posted.
eastenn
eastenn
220
469
Bristol TN
www.fb.com
Sounds good, thanks! Yes if I buy your black ones there will be another set of yellow ones on the market :)
N
NorthPioneer
37
68
CA
Sorry if this has already been covered... does anyone know how much the commander shocks actually lift the p7 front end? I found a set but my pioneer literally just fits into my garage door with maybe 1 inch to spare. If the roof is any higher at that high point at the "hump" in the roof I am toast.
Let me know if anyone has good info on this. Thanks!
Sent from my SM-G930W8 using Tapatalk
SundayRdr
SundayRdr
575
1,179
McMinville Tn
I believe 2-2.5" is what I got with mine
SundayRdr
SundayRdr
575
1,179
McMinville Tn
You can drop the roof to sit on the roll cage behind the drivers head and drill new holes for the rear cage clamp bolts to drop it more than and inch. I had to on mine
Reactions: Gator
N
NorthPioneer
37
68
CA
Thanks for the feedback.... that's what I was afraid of. I'm looking at building a new shed to keep the pioneer in at this point because the bike could use some more ground clearance for sure and there is no way to raise my garage door lol.
SundayRdr
SundayRdr
575
1,179
McMinville Tn
What spanner wrench is used for adjusting the shocks? I would normally use a set of adjustable ribbed jaw pliers but I cannot get the on the rears.
G
green02crew
158
54
I used a pipe wrench, you could also use a screwdriver or punch with hammer and tap the collar around. I've used both methods with good success.
Ems-Cam
Ems-Cam
252
336
Alberta
You could use ratchet straps to compress the spring some then lift unit by the frame to take the weight off, the turn by hand.
Reactions: joeymt33
scott
scott
1,212
1,354
lyman, South Carolina
Where's the post for the ordering of the bushings I need to buy? I already have the pipe.
Fourxjeepin4
Fourxjeepin4
6
Tx
I tried making a new thread but apparently it didn't work so I though that I wouldn't post this here as well.
Hey guys I finally found myself some commander shocks and ended up with two pair to choose from. So I thought I would post the screenname of the guy with the other pair. (With his permission). panamaRed14 on commanderforums.org has a set he is willing to sell.
Gator
Gator
The Most Unknown Member
2,475
10,396
Louisiana
Look at post number 66 of this thread.
Reactions: scott
Tramguage1
Tramguage1
Texan
7,149
27,222
Somereset, Texas
@scott i think i have a few extra bushings with the lube. Ill get back to ya when i get home.
Reactions: scott
searlest
7
indiana
I am in need of bushings and sleeves in order to make this modification
Who's got em ?
Thanks in advance to all contributors awesome details !!
Vato
Vato
180
159
I ordered mine from a place in Oregon. The steel sleeves were sent to buy a fellow formite who had leftover material. I know there is a post some where on this forum. Do a shock bushings search.?
searlest
7
indiana
I have located a set of shocks
Need to get a shipping price .......Does anyone have the dimensions and weight to allow the cost of shipping?
SundayRdr
SundayRdr
575
1,179
McMinville Tn
As mentioned earlier in the post I had issues getting the tubing from the ebay seller and ended up using McMaster Carr. It was 3 day shipping from them too.
