Portals!! Pioneer 1k, 700, and 500!
SuperATV
SuperATV
1,250
8,734
Madison, IN
www.superatv.com
Join in that PORTAL life!
Run some big ol' tires, get lift, protect your drive-line, and gear reduction to get power to the ground!
I'm sure a bunch of you fellas have seen the portals on the 1k's, but due to popular demand we've released kits for the 700 and 500 now. Come play with the big boys! ;)
Pioneer 1000
- 4" Portals: Honda Pioneer 1000 4" Portal Gear Lift
- 6" Portals: https://www.superatv.com/honda-pioneer-1000-6-inch-portal-gear-lift-g3
Pioneer 700
- 4" Portals: Honda Pioneer 700 4" Portal Gear Lift
Pioneer 500
- 4" Portals: Honda Pioneer 500 4" Portal Gear Lift
AKChef
AKChef
5
14
Alaska
If only for the 2014 700-4. What is the difference between a 2014 and 2015? Would the 2015 set work for my machine?
SuperATV
SuperATV
1,250
8,734
Madison, IN
www.superatv.com
Yeah, I can't remember what prevented it from bolting up to the 2014 model, but its not going to be a direct fitment. Not positive, but its often caused by the braking system. Maybe a different caliper mount needed along with different brake lines. That's usually the case.
motorman18
439
277
Laurel, MS
I also am curious about if they will fit my 14 and how much better is the billet over cast
Reactions: SuperATV
SuperATV
SuperATV
1,250
8,734
Madison, IN
www.superatv.com
Good question! I'll have to dig into that. I'd assume they would, but no guarantees because we list it as starting with the 2015 model...unless it was one of those things where it came out in 2014, but is considered the 2015 model. I'll do some digging and report back tomorrow.
Billet aluminum is always going to be stronger than cast steel, but I don't know the actual percentage stronger. Its not a huge difference. Billet is better...and sooo pretty, but if you're counting pennies...there's nothing wrong with the cast. They both have a LIFETIME WARRANTY.
Reactions: DDDonkey and Isaiah
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
cast will crack . billet will scar. think bashing a rock on a portal would you rather a crack or a bent side.
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
man i wish this was posted a few months earlier. i have faith in the satv portal brackets. not so much in the utv solution ones
Reactions: SuperATV
Hondasavage
5
11
Florida
WILL THE 6IN PORTAL, FIT THE PIONEER 700-4?
2021 OR 2020??
IF SO... WOULD I HAVE TO BUY THE A ARMS FOR THE 1000 OR THE A ARMS FOR THE 700?
ALSO SAME FOR THE BALL JOINTS.
IM TRYING TO START MY BUILD BUT NO ADVICE
Reactions: SuperATV and Isaiah
JimmyA
JimmyA
1,644
5,504
Northeast texas
Billet is the way to go, CNC machine from a block of AL. I was in the Aluminum Business for many years! Go Big or Go Home! If, I didn't have so many other needs I would bite on this.
SuperATV
SuperATV
1,250
8,734
Madison, IN
www.superatv.com
2021 OR 2020??
Hey man! Unfortunately we're only making the 4" portals for the 700 and 500 models at this time. They have more tire size limitation, and you would have to have some crazy custom lift to get the wheels and tires necessary for the 6" portals. Those 4"s bolt right up though!
Here's a link!
Reactions: Mudwing and TripleB
