P700 Problem installing aftermarket LED's
bassadict69
30
20
Benton, La
After reading tons of posts and seeing several who had replaced their headlamp bulbs with these, I bit the bullet and placed my order.
The tabs on the new bulbs look like they are correct and they do match up with the slots in the housing, but I cannot push them in far enough to turn a 1/4 turn to lock them into place. Anyone else had that problem?
Stark Industries Phantom Series
bassadict69
30
20
Benton, La
JimmyA, did they install easily?
I have messed around with these off and on all morning and cannot get them installed, even without the rubber washer. I have requested a return through Amazon and will be returning them.
156,597
I read reviews of these after reading your post and some stated that they had to shave down the plastic ring behind the rubber washer or something.
Reactions: Mudwing
bassadict69
30
20
Benton, La
I have not ready many posts at all saying replacement bulbs made much difference, a whiter light, but not brighter, so I will just wait and get a bar soon.
JimmyA
JimmyA
1,644
5,503
Northeast texas
Mine came with 2 rubber washers and I removed one and the install was fine! I did keep them incase later on needs.
V
Vstingray
19
40
Ohio
Sooo much brighter! I installed those exact Stark ones you bought and the difference is incredible! For me, it pushed adding a lightbar way down the priority list.
Did you have issues installing them?
03mossy
03mossy
275
1,080
MN
  2. Other Brand
Yeah they were actually a bit of a pain in the ass. I removed the rubber washer like one of the other members suggested. Then lined up the tabs and turned them in the opposite way you think you should and they clicked right in. Took me longer than I thought it should have.
V
Vstingray
19
40
Ohio
Good to know! Every bit of advice helps
bassadict69
30
20
Benton, La
I pushed like hell and when I would attempt to turn them (either direction), they would pop back out, if they would turn at all.
