P1000m5 Rear Cargo / Cooler Carrier
Smidgy
Smidgy
40
61
New Brunswick
So it happened, I have a run coming up and I have 4 guys coming with me and I need to carry a cooler, more accurately my yeti 45. So what are you guys doing in this situation. Seen the big bed extenders, but I think I could do the same just stapping the cooler down with tailgate down. Seen the racks moses makes and they are sweet, even talked to him about making me one exclusive for my yeti 45 and he was all for it, but I am in Canada and by the time it gets here it will be up there it is going to cost some $$ and making sure thee isn't something else that can be done. I seen some that are using the harbor freight unit with an extender, how is that working? Any damage to hitches? I rider pretty hard and I am worried....Can they handle a fully loaded yeti 45?
The yeti is the only thing I am looking to store, not fuel or tires etc. Just the cooler of that refreshment
Any insight will be greatly appreciated.
aauman88
aauman88
1,091
2,846
5 grown men you better get a bigger cooler :D
Mine works great just on the gate since I got the bracket to sit gate flat. I used a Yeti 45 for several rides and it didn’t hold enough so I upgraded to the 75
I originally wanted a bed extender but didn’t like that it wouldn’t allow seats to be up and gate up without removing it.
Hope it helps
83F6AFC9 B4A5 41FB A832 465AA41ADAAC 18B4ECDB 9C28 46EE 8D32 C701B5FDBF40 09EAF188 E5FF 4B66 98F9 70D0CCFB01DF C6F413E9 F3C1 40F0 9F2B 687C92E2B032 936CF68F 1217 425F 8819 00B4787B2644 05CE77B8 4162 457B BBBE 6B0935A25C3D
Smidgy
Smidgy
40
61
New Brunswick
what are the connections you are using, how are they attached, very interested in how you did that. Also which cables did you pick for the lay flat tailgate?
aauman88
aauman88
1,091
2,846
4 Pack Round Anchor Point Tie... https://www.amazon.com/dp/B07CMDXZG9?tag=sxsweb24-20
JCBIZ 2pcs M8 Turnbuckle Screw... https://www.amazon.com/dp/B07F28PKJL?tag=sxsweb24-20
Ice Chest/Cooler Security Lock... https://www.amazon.com/dp/B0139134HM?tag=sxsweb24-20
That’s what all I used for cooler tie down
Here is the bracket for tailgate to lay flat
KFI Products Tailgate Leveler... https://www.amazon.com/dp/B07GF2BV6Y?tag=sxsweb24-20
New thread, sorry to Hijack this one OP
P1000 - Cooler tie down setup
Reactions: Zax185
Smidgy
Smidgy
40
61
New Brunswick
So I wasn't sure about adding the mounts to my bike and drilling into anything. I come with this, looking into what it will cost to get plasma'd out and welded up. Had to add the "Smidgy" to it. I will keep you informed on how it turns out if I go that way. The cooler is a Yeti 45 for sizing info.
  • UTV Cooler Mount.pdf
