P1000 Cooler tie down setup
aauman88
aauman88
1,091
2,846
got a lot of messages about my new cooler setup. Figured I’d post here and not crowd someone else’s thread. These were not my idea but I can’t find the thread that gave me the idea. The guy bought the anchor setup at a Home Depot. Listed below is everything I used including the brackets for the tailgate to lay flat. Cooler moves from gate to bed depending how many people are riding with us
KFI Products Tailgate Leveler... https://www.amazon.com/dp/B07GF2BV6Y?tag=sxsweb24-20
4 Pack Round Anchor Point Tie... https://www.amazon.com/dp/B07CMDXZG9?tag=sxsweb24-20
Ice Chest/Cooler Security Lock... https://www.amazon.com/dp/B0139134HM?tag=sxsweb24-20
JCBIZ 2pcs M8 Turnbuckle Screw... https://www.amazon.com/dp/B07F28PKJL?tag=sxsweb24-20
(Pack of 4) Steel Eye Link Spring Snap Hooks 1/4" - 6 mm (2-3/8" Lx 1-1/8" W) Premium Quality Multipurpose Carabiners - CLIMBING CAMPING CAVING - Dog Leash, Fishing - Paragliding Clips https://www.amazon.com/dp/B076DTFHM3/?tag=sxsweb24-20
Hope it helps or gives someone ideas for other uses because I love these little anchors.
426439EF 6314 4F6B BA9F 403ACF983C9E 9506BE3D 69FB 4BE7 A87D D099B20A9C2C 166E855A BB02 480F 8A22 B7E3DD150F6D A0E1DA09 F16C 407C B098 1BECD0F47E53 2FB10D84 0714 4257 9017 0D696C86DF02 CDA50105 3D8A 4FB3 9A04 BAD2D70454D7 C0F01687 3DEC 42E8 9EB2 8AEADD5764E3 FACC0CA3 538A 49D0 AFB4 A851913BA43A C4EA05DD 949C 4CAE BD07 E4C9D6E71600
That’s really cool and a good idea to make your own thread with this. I’m not near either Pioneer this week and I’m curios about how solid the tailgate is at the two points you installed the quick release tie downs?
Also, are the cooler security locks germane to all upper end ice chests, or are those specific for your brand of chest, which is quite funny I’ll add...:D:cool:
aauman88
aauman88
1,091
2,846
Tailgate does flex some there but not enough to bother anything I don’t think. The tailgate will still pivot up and down as cooler is still about 1.5” from hitting the rear of seat. If it’s an issue I will reinforce the gate but I have had my Yeti 45 mounted on gate for several hard mud rides with no issue but was tied down a different way.
The lock bracket is universal to roto molded coolers as long as they have the tie down slot. I own several different brands and they all have them but sure there are some that don’t.
Reactions: sharp
Oh, it’s a Yeti, I thought it was a cold bastard, as in brand name, lmao.:D
Thank you for the information, useful. :cool:
aauman88
aauman88
1,091
2,846
The new red one is Cold Bastard brand. I have Pelican, Yeti, Ozark and RTIC coolers. The Cold Bastard is built as good if not better than all of those and it’s much cheaper than Yeti or Pelican. Also get a lot of extras included with it.
Reactions: MMW and Montecresto
aauman88
aauman88
1,091
2,846
Changed setup a little for the larger cooler to get weight off the tailgate. The front tie down holds probably 80% of the force and the rear one is just snugged up to keep it from moving. Big cooler got very heavy when loaded and was worried about gate. Will still use the other way with the smaller cooler. Even added drink holders on each side for when BS’ing around the back. Still able to remove cooler or relocate it to inside bed within a minute or two.
A35AA5C3 8A7F 4B6F B915 399566C2873F D354AC39 6BAD 4F25 85A4 E92B6572FE4C 841A4B26 172E 40B7 9B29 721E37790D0B
