P1000 2023 1000-6 Dual Battery Setup
T
TexasSpartan
Tennessee
  1. 1000 6 Crew
Hey all, picked up a '23 1K6 this past weekend and dealer is currently waiting on a couple accessories to come in and install. Hope to have the rig by this weekend. I'm interested in installing the dual battery setup as my first mod. It seems there are many ways to go about this so wanted to ask what is the most current install that you all would recommend? I've watched Robert Sparre's vidoe a couple times but I'm seeing that the '22's and '23's have additional wiring for adding accessories. Is Robert's method still the best way to go or is there a more recent version I'm not seeing? TIA.
115,818
Welcome from the Radical Leftist run Michigan!
First things first when you join is pics. Its Rule #4 or….
Pics Or It Didnt Happen!
For your battery set up, check out the forums Club store for the the kit you need for that. We like to support the Boss and The Forum when we can.
Also check the search on how to’s and pics of how others have done it cuz we have! 😉
Reactions: ChadD and JenElio
JenElio
JenElio
74,961
676,534
Loxahatchee, florida
Welcome to the club from south FL
Like the sheriff mentioned.....POIDH!!! 😂
There's more then one way to skin a cat sooooo basically what works for you is the "best" way of doing the job. Club store has a lot of plug-n-play stuff 👍
Reactions: Remington and ChadD
HondaTech
Even with the Honda acc. fuse box installed there is still room in the spot most install their 2nd battery.
Wisco-Tango
Wisco-Tango
72
243
Fisk, Wisconsin
I am planning to use the OEM fuse panel on mine when it gets here. You can check out this thread for more info on the fuse panel. The boss did a nice write up on it.
