P500 Rectifier getting extremely hot
Mudder
Mudder
NTC Ambassador of Walls
11,352
84,485
Had to replace the voltage regulator on my ‘17 P500. Its overcharge failure also damaged/swelled the battery. Returned an aftermarket rectifier (plugs did not fit) and replaced with OEM one and new battery. Ok since. Here’s my original post.
Reactions: pappyo
Scoop
Scoop
4,241
15,885
  3. Talon R LV
Fixed, rectifier was the problem.Thanks for the assistance.
Be sure to monitor it regularly for a while. It's not uncommon (at least when I used to ride 5th and 6th Gen Honda VFRs) for the stator and/or connections to be the root cause, and the regulator/rectifier burning out is/was only a symptom of the actual problem.
Reactions: Mudder and CID
