Multi Help. Voltage high and climbing
Mudder
Mudder
NTC Ambassador of Walls
11,692
88,500
C86495C7 221E 4D5A 9FC3 4A83C1BA1F23
Voltage output climbs while running, went up to 17.7 in first 20 seconds and climbing when turned the engine off. Engine off, battery reads 12v. The climbing voltage is causing a radio to cycle off as the radio works constantly just off battery 12v. May be the reason I had to replace the battery yesterday. Where is the voltage regulator, or rectifier located on a P500? Parts diagram shows it as item 3 but no location. Thanks
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
Voltage output climbs while running, went up to 17.7 in first 20 seconds and climbing when turned the engine off. Anyone had problem (P500). May be the reason I had to replace the battery yesterday.
yeah you need to get that checked out. normally should run 14-16 at the most. anything past 18 and your gonna start burning things up
Reactions: Mudder
99Burban
99Burban
30
75
The rectifier (item 3) is bolted to the back side of the battery box if i recall correctly. It is easy to reach if you pull the rear fender/rack assembly.
Reactions: Mudder
Mudder
Mudder
11,692
88,500
Thx, found it, hard access.
Mudder
Mudder
11,692
88,500
Checked all connections including rectifier. Noticed because radio cuts out above spike of voltage operating range of 16+v. Video of spurious voltage at idle. Smooths out at 14.3 volts at higher rpm. Ideas?
99Burban
99Burban
30
75
The service manual could probably help but i am nowhere near mine at the moment. Before i bought the book i would go to my local dealer and chat with the mechanics..they were always helpful.
Reactions: Mudder
Mudder
Mudder
11,692
88,500
No luck at dealer, any manual info appreciated. Looking for a good place to order one for future use, any suggestions? Some starts went to 18 v, others up to 16, very erratic spikes.
Neohio
Neohio
Beast of the East
17,948
86,632
Painesville Ohio
Shoot me a PM when you have a few mins. I have a manual for a 500.
Reactions: 99Burban
Mudder
Mudder
11,692
88,500
All meter tests OK on wiring harness side, but no info found elsewhere on testing the regulator/rectifier itself. Still 18 v so a new one on order.
Reactions: Mudwing
Alan_Vander
Alan_Vander
1,547
2,751
rosepine,la
thats really the only way to test the regulator is by cranking it and monitoring with voltmeter. i dont think their is an ohming guide to those like some other equipment. but i could be wrong
Reactions: fallrisk
Mudder
Mudder
11,692
88,500
Voltage on disconnected alternator output harness shows steady 12.4v and engine starts and run smooth without the regulator rectifier installed. All this seems like a process of elimination. Maybe the GA heat wave and idling for long periods while doing chores overheated things causing overcharging. Battery was bulged out so replaced. Regulator was $150 at dealer, $40 on internet. An simple related video on harness testing.
Ragnar406
Ragnar406
The Great Bald One
4,450
17,035
Bella Vista, AR
Did all this fix your issue?
43,293
@Mudder, when you were poking around the regulator, did you notice any oil in the plug in?
Last few times I've had mine unplugged, there has been a little oil in the gray connector.
I don't know if these are filled with oil, but it seems strange that it would go "up". My only other thought is that some oil is leaching through the wires and into the connector (since the other end runs into the crankcase).
Mudder
Mudder
11,692
88,500
No oil, the connectors were very tight to remove. Wires dry. Drilled some holes in bad unit, dry gray shavings from inside.
37D2F9E5 B176 4658 B609 F1F33C15862F
Reactions: DG Rider
Chaos0101
Cairns
Just found oil in my regulator. What did u have to do stop this from happening ?
Reactions: DG Rider
