P1000 Request - 1st service filter picture! Pioneer 1000
64,009
Hello,
I did my frist service a few weeks back. But I totally forgot about this. Now I can't find them!
Anyways....
I am looking for someone who just did their first service that can take the filters apart and see what is inside.
Need BOTH Oil and DCT filter.
I am interested in knowing how many metal shavings are inside the filters.
It is also worth noting that both mine and @JACKAL's filters were black. Is yours?
Here is a example of what I am looking for. - Metal Shavings in Oil Filter!
So.. Post some pictures of your Pioneer 1000 filters taken apart.
Thanks.
266,553
Here is what My Filters material looked like with only 160 miles on the P1K compared to a P700 below it. Note the color of the filter media, black vs. oil stained yellow that is normal.
P1K 160 Miles:
P1K Oil Filters Black at only 160 miles
P700 111 miles:
Typical Oil Filter 1st Change
266,553
Jackal did you check shavings to see if they would stick to a magnet
I drained the used oil through a T-shirt and did not have any "chunks" or "fiberous material" come out.
The oil I replaced it with 5w-40 full synthetic. I have ran it in my Rincons and Ranchers as well as my trucks for years without issues.
ghost
ghost
993
1,873
BC
I did mine today.
The filters got a bit contaminated when I took them apart but you can see the shiney bits. The larger white pieces are glue from the filter that fell in there on removal. Most of the filters didn't have a lot of metal. These are the worst areas. Engine filter had more metal.
IMG 2452 IMG 2455 IMG 2456
Reactions: JACKAL
ghost
ghost
993
1,873
BC
Filters before and after.
IMG 2430 IMG 2432
Reactions: JACKAL
tundraman
tundraman
141
175
The oil I replaced it with is 5w-40 full synthetic. I have ran it in my Rincons and Ranchers as well as my trucks for years without issues.
I use T6 in my tractor but still won't use it in any other equipment. I use Mobile 1 4t in my bike and Mobile 1 in my car, truck, ZTR, etc. Still not sure why people use diesel oil in everything?
Bayouownbeer
Bayouownbeer
789
1,073
Chauvin LA
Maybe try to go back with regular 10w-30 Honda oil to see if shuttering stops being it started after the oil change
266,553
Yes, I'm going to give that a try. Got 4 gal of Honda GN4 10w-30 and 2 sets of filters on the way.
Reactions: Bayouownbeer
Up2It
Up2It
Calgary Alberta
The Rotella T6 is JASO MA rated, which means it is safe for a wet clutch. Mobile 1 is not rated for a wet clutch. (as an example) Most of the diesel motor oils are rated to be used in a wet clutch environment I believe (you still have to see the Jaso Ma rating)
ghost
ghost
993
1,873
BC
@ghost, Did I miss it... How many miles at service?
92 miles (148 km in case anyone from the rest of the known universe is watching)
I think someone was suggesting that we could go past the recommended oil change service interval but with mud like that, it wont be me.
Reactions: Hondasxs
tundraman
tundraman
141
175
Mobile 1 t4 is engineered for wet clutches of motorcycles and works great in my bike. Yes its a few bucks more a quart than t6 but its made for bikes, not diesels. They even put pictures on the bottles so people can figure it out. Ea69a3ab816534021ff36382175445793c309 webp 450x450
Bayouownbeer
Bayouownbeer
789
1,073
Chauvin LA
100 miles went back with 10w-30 Honda oil. Oil was dark, but I wouldn't say burnt or burnt smelling. Good bit of Aluim in the filter
Image Image Image Image Image Image Image
