SATV Driveshaft Reviews
5,037
22,524
Oh. My factory cv joints were not loose one bit. In fact they were almost sized up. I could barely move them by hand.
Factory CV joints or factory U-joints? I ask because what do the CV joints have to do with replacing the driveshaft? Inquiring minds need to know this sheet.
I haven't noticed any zzzzzzz but I do have any annoying howl in 4wd. Quits as soon as I turn it off. If it doesn't quit, I have to blip the throttle to unload the driveline for i4wd to 'unhook'.
Reactions: 906UP and Smitty335
63,698
I guess I am referring to the U joint on the drive shaft.
I could not move either end by hand.
Reactions: CID and Smitty335
Todd627
Todd627
56,308
615,255
MI
Damn, that's tight. :oops:
1698024347403
906UP
906UP
13,051
121,714
da Yoop
It eliminate most of my zzzzz up front.
I still have some also.
Has to be in the differential.
Idk.. I give it a 70% improvement score.
The front diff has a different gear ratio than the rear, not much but it is different, IIRC the front ring has 1 more tooth, might be the other way around. I've found that the growl could be eliminated by adjusting tire pressure, I run the fronts about 2 psi higher than the rear.
Note, this is with the same size tires F & R.
5,037
22,524
The front diff has a different gear ratio than the rear, not much but it is different, IIRC the front ring has 1 more tooth, might be the other way around. ...
Fwiw: that's been done 'forever' in 4wd vehicles - something about engineers want the front end pulling the rear, they don't want the rear pushing the front. It's why you should never run in 4wd on pavement, you'll bind up the driveline to the point of failure.
Reactions: Smitty335 and 906UP
SLOWPOKE693
SLOWPOKE693
1,615
6,135
Somewhere in Texas
1 tooth difference has ZERO effect on making the front "pull" and will not screw anything up running on pavement in 4wd. Ultra 4 cars have been using different F&R ring and pinion ratios in the 20 to 30% difference range for years with no I'll effects even on pavement.
  • Wow
PhilCod
PhilCod
337
701
Indiana
Good write up. Time for my driveshaft fix. May go with SATV just for the fact that it would quiet down the driveline noise. Otherwise I may just change the u joints. I'll see what it looks like when I get the skid plate off. 4,600 hard trail miles on mine.
906UP
906UP
13,051
121,714
da Yoop
Get the SATV driveshaft, you won't regret it
Reactions: User242 and PhilCod
Teebow
Teebow
281
1,185
Kentucky
  1. Talon X4
4500 miles on mine, could probably go another k maybe. Started hearing chatter on the road above 35 mph, felt a little play in front shaft. Honda warranty is covering it currently (in shop). If satv had one for a 4 seater may have considered it.
A
adegraw2147
Walls, MS
We replaced the driveshaft yesterday in ours since putting it back together, the 4wd light is on and will not go off. Any ideas?
Hometeam
Hometeam
938
3,697
Normal, IL
Make sure you have all the speed sensor plugs got plugged back in. Ours was on after also and it was the speed sensor connector on top that is harder to get to that was the problem.
PhilCod
PhilCod
337
701
Indiana
I had my dealership put mine on over the winter. Nice and quiet now. I have about 500 miles on the SATV one. So far so good. I did keep the old driveshaft. I'll probably replace the U joints so I have a solid back up. I'm at 5,200 miles now. I'll probably shake it out around 8K.
