P1000 Shift solenoid location
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
I'm looking for a detailed description of the shift solenoid location and how to access it. (I know, I need a service manual). I have the skid plate off and found the 3 oil sensors and heard its behind the clutch cover but I'm not sure of the process in taking it off.
Thank you
Sign up for the lifetime membership and you have access to a digital copy of the manual..
Reactions: Mudwing
RyanG
25
12
NORTH BAY
Thank you
Did you find them. Also wondering because im having an issue with my bike in low gear its not shifting properly. But high gear works. Does that make sense. Is there 2 separate solenoids for the high and low gears.
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
The shift solenoids are located behind the clutch cover. But they wouldn't have anything to do with high vs low shifting. What do you mean by not shifting properly in low range?
RyanG
25
12
NORTH BAY
So i can drive in high gear no problem but as soon as i put the bike in low gear i start to go and its like when its shifting from 1st gear to 2nd gear its a loud clunk and i just stop bc its not right at all. But like i said last week i did the clutch re teach thing and i tried low gear in the yard and it acually seemed like it fixed the problem i could hit the gas and probaly went into 3rd gear in the yard so i thought that i fixed it but i went for a ride down the road and i stopped to try low gear again and it went back to normal. As soon as i touchdd the gas it clunks loud.
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
It's fine. The clunk right before each shift is the shift solenoids working. It's 100% fine. They make the same noise in your car but you just can't hear them. It's literally just the knocking of the solenoid when it engages. Mine is also slightly quieter in high. When I first got mine I thought it was the drive shaft that was loose, lol. More info if you do a search for "clunking noise".
RyanG
25
12
NORTH BAY
Ill try to get a video of it. I took the seat off and it comes from the sub transmission area and when it clunks its super loud and sounds like something is literally gunna blow up. Kinda disappointed with this pioneer. Figured with a duel clutch transmission it would be better than what it is. Not sure if im to convinced with it. Bought it bc no belts anymore and fits my young family.
Reactions: Ryan Dorsey
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
See if you can take a video. The problem that I had turned out to be a broken wire from shotty dealer techs when they did the clutch update. They didn't fasten the wire harness back up and the wires rubbed on the drive shaft. I have over 7,400miles trouble free miles.
RyanG
25
12
NORTH BAY
How do i add a video. Says its to large of file. I cut it to 10 secs too.
Neohio
Neohio
Beast of the East
13,422
65,854
Painesville Ohio
Upload your video files to youtube, copy/paste the link here. IT will auto insert the video to your post.
RyanG
25
12
NORTH BAY
Weird eh. Also like i said i reteached the clutch couple weeks ago and it stoped doing it in the yard and i went for a ride and tried low gear and it was back to this.
ehart814
ehart814
1,654
3,643
NWPA
No bueno...
It doesn't do this in high??? I'd suspect that Low range in the sub transmission is effed.
T
T-County
26
46
Tennessee
I'm just curious. I've read that the voltage has everything to do with shifting. One video touched on having dual batteries. Think that might be a possibility ?
RyanG
25
12
NORTH BAY
So when i had it in the shop im pretty sure the mechanic was talking about possible short somwhere or talked about a relay possibly. Its got the original battery and i have a voltage meter on the dash shows 14.2 volts while running.
T
T-County
26
46
Tennessee
T
T-County
26
46
Tennessee
gotcha. I was just putting that out there
You need to quit driving it. How long has it done this? If you disconnect the shift fork cable and manually put it into gear will it still do it?
