P1000 Shift solenoid location
Delton
Delton
Honda Fanboy
9,967
31,485
Middle TN
I'd bet dollars to donuts the dogs on your low gear are rounded off. If it's like a motorcycle (and probably is), gears just grab by the tip of the dogs. As mentioned stop driving it. Either take to someone to tear into subtrans or do it yourself.
P.S I'll be here waiting on them donuts lol
RyanG
25
12
NORTH BAY
You need to quit driving it. How long has it done this? If you disconnect the shift fork cable and manually put it into gear will it still do it?
I was told by honda i can still drive it in high gear. But said stay outta low gear. But i need it fixed bc i wanna do yard work and riding and need low gear. I will try to disconnect the cable today and try it out. I cant get my bike into shop with tjis virus s*** going on. So trying to figure it out on my own if i can. And i bought the bike used and in march and got home and found out low gear did this. The guy lied to me and fu*ked me over fortunately.
Reactions: TripleB
Well, you’ve got one of two things going on. Either the cable is stretched (or needs adjusting) and it’s not fully engaging in low, which will wear the dogs or your dogs are already worn and you’re going to have to get in the sub trans. Pulling the cable off should tell you which.
RyanG
25
12
NORTH BAY
Ok thanks guys. Ill pull cable off today and put it in low gear manually and see. So if i put it manually in low gear it shouldnt do that anymore? Meaning cable is stretched? But yeah am aware of things are probably rounded off.
Reactions: TripleB
Exactly.. if it’s just the cable you should be able to adjust it out, if it still does it manually then you’re screwed and have to crack the sub trans.
Hondaray1011
12
20
Florida
My buggy shuts off when I take it out of park and want crank in gear but will crank in neutral
The shift solenoids are located behind the clutch cover. But they wouldn't have anything to do with high vs low shifting. What do you mean by not shifting properly in low rang
Hondaray1011
12
20
Florida
You need to do a clutch relearn, If it fails you probably need clutches
Did a relearn and nothing and I can drive it once it gets going no problem at all then ride again and what shift out of 1st gear and then shuts off
  • Wow
HondaTech
Year?
Miles?
Dash flashing anything when it shuts off?
Does the gear indicator work properly (displays correct sub gear)?
Reactions: tjoreo
Hondaray1011
12
20
Florida
Year?
Miles?
2016 3500 when it dose yes it flashes a e and yes it works properly but when it is running, it is really hard to move but if I shut it off it moves like it should
107,430
@Hondaray1011
Yes, have u ever had the clutch update done? Very important when were talking about 16’s to help u further.
Also Welcome from the Putrid Swamp controlled Michigan!
We need pics of your rig! Its Rule #4 when u join and first thing u do when u post, problem or none
Pics Or It Didnt Happen!
  • Haha
Hondaray1011
12
20
Florida
@Hondaray1011
No update that I know if I just bought about 5 months ago
107,430
Might be your issue then.
still need them pics tho #POIDH
Here is some info on the update campaign,
I suggest you read up on it. Find out with the bottom pic and report back with your findings so we can help u further.
9CA36A40 AF27 48C4 9178 AB82E4A98A45
Reactions: CID and Smitty335
G
GaCracker
Ga.
@Hondaray1011
I do NOT have a 'smart phone' to take/post pics so I guess according to "the sheriff" I'm not eligible to ask for help,, right?
  • Haha
Reactions: Remington
107,430
Total BS. You can ask for help.
Taking pics isnt for me. Im doing the work for the people by the people. Its the mob you need to worry about. Im just helping you before hand.
Im sure your wife, girlfriend, boyfriend must have a phone or a camera of some sort? So that old bit dosnt work these days;) and a name with Cracker in it, i find it hard to believe u dont either. But who am I to judge.
At any rate, hell of a first post since joining 2yrs ago there buddy ;) Way to come out all guns a blazen.😂🥳
Ill start with….
Welcome from Michigan
You can start an intro thread like everyone else please. Tell us about yourself, your rig model, your , Miles and your mods. Pics are an unwritten rule requirement tho for the last 5 or so yrs.
When u do that intro, youll be introduced to the mob (if u have no pics for proof of purchase) and youll see its not me 😘 NoHmo
See yoy in your intro thread
