P500 Skid Plate Install - Rivnuts or Self Tapping?
Red500
Red500
5,309
57,578
Greeneville, Tn.
I was going to start putting in rivnuts, but it looks like that's not recommended?
Reactions: JenElio
The Green Goat
The Green Goat
1,777
12,643
Ohio
This is probably the best thing to use for longevity.
1000002524
Prntckt
Prntckt
1,049
7,226
Altoona, WI
  1. Talon X4
Which have you done? Regrets?
I've done self-tapping into the tube frame, a few of which keep pulling out. Then again, I hear the rivnuts can spin, bolts break as well.
I installed the skids on my Pioneer and Talon using rivnuts. No complaints. Work great/easy to install. Had a few rivnuts loosen up, but easy to replace too.
On my Pioneer, I had several of the skid bolts seize up in the rivnut. I put antiseize on the skid bolts of my talon, and have not run into any more problems with rivnuts seizing, i have found a missing skid bolt/washer that vibrated loose, but only a couple of times. . I check them everytime I do an oil/filter change.
Reactions: futzin
futzin
futzin
3,245
23,369
Kentucky
I like the plus nut idea, but trying to use a setting tool up under there . . . ? . . . tight quarters
1/4-20 size ok? zinc ok? what size hole to set them?
Reactions: Coeus and Red500
lee
lee
Village Idiot
2,342
13,150
Springfield Ohio
You can get the riv-uts/+ nuts in metric sizes, the skid plate bolts on the stock p520 are M6.
Or you can use 1/4-20.
My only recommendation is don't mix them.
Nothing more fun than laying in the mud trying to put it all back together and the last 1/4-20 bolt is not wanting to start in the last remaining M6 hole.
NTCPrezJB
NTCPrezJB
President of #NTC
101,496
906,760
Canton, OH
Protip! 👏🏻👏🏻
futzin
futzin
3,245
23,369
Kentucky
I don't suppose a plus nut setter is a tool that one can rent? 🤔
Looks like 85 -90 to buy one . . . a riv nut tool is much cheaper.
266,477
I've done self tapping and after a dozen rip out of 40ish bolts time to do it right.
Ditto I went with these from Amazon 4 years ago, still have plenty to do my new P1K5D next week.
futzin
futzin
3,245
23,369
Kentucky
Currently leaning towards rivnuts. I'm don't seem willing to buy the plus nut tool. :rolleyes:
I'm away from the buggy so I'm trying to think ahead for what I'm gonna need once I get back into it.
Reactions: NTCPrezJB and Coeus
futzin
futzin
3,245
23,369
Kentucky
ordered plus nuts, setting tool, bolts, drill bits . . . Critter's skids need upgrading too, and the 520 is just a matter of time
And a thank you to @The Green Goat for activating my Catholic guilt . . . 😁
futzin
futzin
3,245
23,369
Kentucky
Working on Critter's skid plate. Several self tappers had come out.
The plus nut setter seems to work just fine. The online info said a 9mm hole for them, but it's too small. Using 3/8.
The problem: in removing the two main center pieces of the SSS skid, two of the factory mount bolts snapped.
I drilled one of them out, but now can't get a bolt to thread. Self tapper here? Try to drill it out for a plus nut?
The other is worse. Tried to get it out with extractors; the bit snapped off in the hole and has fused/galled. Can't get a drill bit to bite to drill out.
Suggestions?
  • Wow
Reactions: KyGal83 and Coeus
