P500 Skid Plate Install - Rivnuts or Self Tapping?
futzin
futzin
3,151
22,664
Kentucky
Your way past to getting that bolt out.Move your new bolt to a different location slighty.Use a rivnut into frame somewhere just recess the skid plate some.No one will know but you and me I WILL NOT TELL.
That occurred to me as well.
futzin
futzin
3,151
22,664
Kentucky
Boogered threaded mount. Don't know if there's enough to re-thread for larger bolt?
20240316 103700
Shots of sheared bolt, sheared extractor.
20240316 103555
20240316 103820
20240316 103841
futzin
futzin
3,151
22,664
Kentucky
For the forward location (the sheared bolt spot) I should be able to install a +nut or two instead.
For the rear location (boogered threads), that's at a spot where two pieces of the skid come together so I need something there.
Can I rethread that spot? With what, a tap? One that goes into a drill, or one with a T-handle thingy?
Can it be drilled out hollow to accept a +nut?
Other thoughts?
TIA!
JenElio
JenElio
64,329
603,504
Loxahatchee, florida
Other thoughts?
TIA!
If you can't drill out the old one, maybe you can use a spot weld drill bit. It's basically a mini hole saw but.......might work 🤷‍♂️. If not and it were me, I'd run a self tappers right beside the broken bolt.
futzin
futzin
3,151
22,664
Kentucky
A nearby substitute anchor is indeed the plan for that spot. but with a +nut or two.
I just need a plan for the spot with bad threads. I need to use that spot. I don't know if I can re-thread it or not.
Do I have to go bigger; from M6 to M8? Or should I try to rethread with M6? Or try to ream it out with 3/8"?
Reactions: NTCPrezJB
futzin
futzin
3,151
22,664
Kentucky
Are the threads just in the metal of the framing material, or is there an insert of some kind?
156,461
You'll probably need to go up in size.
futzin
futzin
3,151
22,664
Kentucky
Update: I got the sheared bolt spot drilled out, ready for a +nut. Slightly off center; the pilot bits wandered away from the fused mess but it should work.
I'll try an M8 tap in the other spot.
Thanks!
( . . . worst thread ever . . . ) :rolleyes:
futzin
futzin
3,151
22,664
Kentucky
No metric taps at the local Homey Despot. So I drilled it out to 3/8". Plus nuts now in both locations.
Much ado about very little, I know.
No more Critter work until Monday. Hopefully get the skid pieces back on then.
Certainly appreciate the help!!
futzin
futzin
3,151
22,664
Kentucky
Skids reattached, all good.
What a boring thread.
Thanx
Seriously, a big 'thank you' to @lee for the plus nut / x nut idea. Seems more secure than the rivnuts. I only heard one of them snap from overtightening.
