P700 Squeeky cab enclosure
L
Leiske
Wa
I have a new 700-4 and I installed the Honda full
Cab enclosure not including the dumpbox enclosure. Getting used to the suicide doors.
The front of the box rubs on the rear panel of the cab. If any of you have had this issue, I would love some suggestions for keeping them from rubbing. I am afraid over time the metal will run through the plastic.
NewHere2
NewHere2
Village Idiot In Training
36,282
307,854
High Plains of SD
Did you check to make sure the rear cab portion is properly installed ? Did you follow the online Honda instructions ?
There should easily be a fingers width of clearance between the back of the cab and the box. If that is where it’s rubbing.
Can you post a couple of pics
Reactions: Buggyman
L
Leiske
Wa
Thanks for the fast reply. See attached pix
E387B7A2 901E 4923 BD13 1CD61C6B3BD0 CF9D6A67 68C7 48F2 9E65 48C337EAE479
Buggyman
Buggyman
34,986
298,186
ne. ohio
The suicide doors are a nice change from the old regular ones I have, make it a lot easier to get in and out. The dump box on mine also touches the back of the cab. was on it when I bought it in 2016 the buggy is 2014. only problem I had was squeaking when the bed wasn't latching down right, was missing one of the rubber bumpers in the frame that it sits on when closed. you could loosen all the mounts and try putting something in between the bed and cab then retighten mounts or try slowly heating it up with a heat gun to see if you can't get a small gap in there. good luck and enjoy the buggy
Reactions: NewHere2
L
Leiske
Wa
Thanks for the suggestion
thanks
Reactions: NewHere2
