P700 Starting in the cold?
joeyaffhy
joeyaffhy
23
68
Mass
My 2020 700 starts hard on these cold new England mornings here in Massachusetts. I have found if I turn key on and let the dash gauge cycle. Then when starting the engine I lightly tap the gas peddle as it is turning over and the machine starts every time first try. A little weird for a fuel injected engine, but works for me every time.
Reactions: TripleB and Mudwing
E
eagle-E6
Alberta
My 700-4 wouldn't start yesterday (-30 C). I've got 10W30 oil in it, and a fully charged battery. Was thinking of using a heating pad of some sort, and changing the GN-4 oil to a 0W-20 synthetic. Has anyone used ether as an assist for extreme cold weather starting on these machines?
G
Grasshopper
20
46
Pa
Tapping the gas opens up the throttle valve which will let your engine turn over slightly faster due to less air restriction. I'm guessing that is why it might be helpful on a fuel injected engine.
tjoreo
tjoreo
1,011
1,929
Southern Idaho
I have said it before on here but my 700 was a bear starting in the cold. I tried everything from battery tenders, lower viscosity of oil, to better fuel. What finally solved my problem was a bigger battery. After alot of research I found the Canadian models come with a bigger GYZ16H 16 ahour battery vs the smaller YTX14 battery in the states. I was actually able to put an even bigger battery YTX20 with 310cca in the stock location by trimming the plastic divider next to the battery. I found once that it says if the starting voltage drops to about 10 volts it will actually turn off the injectors and it won't start. At least on the Rincon. I think this is the biggest issue and believe even the Rincons come with the bigger 16 amp battery. Don't ask me why honda did this other then for cost savings but it cured mine with the bigger battery.
tjoreo
tjoreo
1,011
1,929
Southern Idaho
Reactions: Mudwing
Slackjaw
Slackjaw
277
452
Durham NC
I have said it before on here but my 700 was a bear starting in the cold. I tried everything from battery tenders, lower viscosity of oil, to better fuel. What finally solved my problem was a bigger battery. After alot of research I found the Canadian models come with a bigger GYZ16H 16 ahour battery vs the smaller YTX14 battery in the states. I was actually able to put an even bigger battery YTX20 with 310cca in the stock location by trimming the plastic divider next to the battery. I found once that it says if the starting voltage drops to about 10 volts it will actually turn off the injectors and it won't start. I think this is the biggest issue and believe even the Rincons come with the bigger 16 amp battery. Don't ask me why honda did this other then for cost savings but it cured mine with the bigger battery.
Can you link us to the YTX20 with 310cca?
All I can find is 270cca.
Thanks!
tjoreo
tjoreo
1,011
1,929
Southern Idaho
Here's the one I used. Like I said you will have to trim out the little plastic piece next to the battery, but after it's removed it looks like this should have been their original idea because it fits perfect. If I remember right the difference in the 310 vs the 270 was just the height but it will fit. I liked the battery size so much that when I sold my 700 I actually took it out and used it as the secondary battery on my 1000. I hope this helps you out, but it cured my starting problems. My 700 was the worst starting machine I have ever owned when the temps dipped into the single digits.
Slackjaw
Slackjaw
277
452
Durham NC
Thanks!
I may use this as the starting battery and the stock one as the secondary.
Reactions: joeyaffhy
tjoreo
tjoreo
1,011
1,929
Southern Idaho
On my 700 I didn't do a secondary battery. I was planning on doing it by adding a secondary battery the same size as the original. I actually bought a blue sea switch that I could actually combine the batteries to help with starting, but the bigger one fixed my issue. If you are thinking about a secondary battery I believe alot of the early 700 owners were installing a car size battery under the driver seat. This might be another option and with the switch like I was talking about you could combine them if the need arises. Just know you are not the only one that has had trouble starting in the cold and I hope you can get something that works for you.
Reactions: Mudwing
Harvester
Northern Wisconsin
  1. Big Red
I have a fuel injected Grizzly 700 2016 turns over slow with a new HO battery . Was mentioned the computers for fuel injection are not very sophisticated for these machines . My Grizzly never ever starts on the first try when below 50 degrees and that is with a new fuel pump . For fuel injection these are poor examples . IMO they ought to be starting immediately or with in a few cranks of the starter .
Glock21user
Glock21user
" Nothing succeeds like excess "
1,815
9,039
Livingston county, Mi.
I would mostly agree, yet to add the level of sophistication needed that would require more sensors, better ecu programming and mapping which would require lots of hours of R&D.
For the use and price point of these machines I am fine with what I have.
I hear alot of comparisons or just complaints about what they should or could have done but at the end of the day the simplicity and ease of repair is a definite trade off I will take.
7
7for4
Sonora, ca
Watched an interesting U Tube video yesterday on this subject. JoAMoN was having this trouble. He changed out his spark plug to an iridium plug...seemed to work for him. Link:
Hope this helps.
