STI wheel/tire combo.
266,520
sti
STI HD4 , 14 inch
@Kenjones21 I think he wants to know what tires you already have mounted on them too. May save you from taking them off they always make more. :)
Kenjones21
Kenjones21
164
103
Central Louisiana
I had 30x10x14 Outback Max mounted to them but got them taken off today ( my neighbor has a tire shop ;)
chadbo
chadbo
Mama tried
2,044
5,658
Seminary , Ms
I like the look of outback max
have you used the outback max before? I am thinking bout using them. Are you going with the deluxe? Maybe put the radial 27s on your 4/110 rims would make a nice setup for a 700 owner if you could use factory deluxe rims that is.
I really like the Blackwater Evolution 8 ply it was tough tire
Gonna go with a 30x10-14 though
2a139915c0bb3d0b0ea2cc7bfe368160
21a150a2f975e8a7d3bde5be3ab434f4
After getting a look at the P1000 first hand, I'll probably just put Blackwater Evo 28x10-14 all the way around so I can carry a spare and it fit anywhere(assuming the front and rear offsets are the same) Clearance is as good as my 700 when I had it lifted and with flex I'll probably run into rubbing or contact issues if I go with 30's.
chadbo
chadbo
Mama tried
2,044
5,658
Seminary , Ms
Saw they offer front or back rims would that mean the offset was different
Kenjones21
Kenjones21
164
103
Central Louisiana
I've spent a weekend on a can am maverick with the outback max on it , I was very impressed on how smooth they rode and pulled very good also , they don't pull like outlaws but probably pull better than any other tire that isn't pure mud tire
educ8tedguess
educ8tedguess
403
972
Spring Grove Illinois
  1. Looking to buy
For those looking to go to larger tires, will 28's or 30's clear without a lift? I have 28 inch blackwater evolutions that I may mount on the stock wheels if I don't need a lift to do so
chadbo
chadbo
Mama tried
2,044
5,658
Seminary , Ms
Pretty sure going up 1 in you should be ok I'm really hoping to go all the way to 30s
After seeing a 1000 I'm worried 30's may rub while compressed and turning, I think they will be fine sitting still but that's not why I am buying this thing. Luckily I'm getting a Silver Metallic and someone else can be the lab rat.
chadbo
chadbo
Mama tried
2,044
5,658
Seminary , Ms
Me too I wish it would have been jet black but that's the closest thing to it.
