P1000 System 3 xtr370 tires / st3 wheels
Hondoman
Hondoman
727
1,697
Texas
Put my new wheels and tires on today. Xtr370 30x10-14 tires, st3 wheels and @RB3offroad 4 /136 to 4/137 1" wheel spacer on the rear only. No lift, fox qs3 shocks and superatv arms front and rear. Looks like everything clears, but will have to see if it rubs under compression. Camber needs adjusting too.
20200325 193757
20200325 193139
20200325 193206
These tires are so new, very few reviews exist. Not sure when I'll get to test them out with the current shelter in place county order....
Hondoman
Hondoman
727
1,697
Texas
Heres the adapter/spacer:
Maybe its placebo, but the lug nuts went on smooth as butter (wheel to adapter). Needed a spacer anyway so I got the adapter.
20200325 170508
ehart814
ehart814
1,654
3,643
NWPA
very sharp. Every time I see that camber issue with those arms it makes me wonder why anyone would sell those arms if that's the result. Seems ridiculous to me.
Russ989
Russ989
22,575
146,615
Put my new wheels and tires on today. Xtr370 30x10-14 tires, st3 wheels and @RB3offroad 4 /136 to 4/137 1" wheel spacer on the rear only. No lift, fox qs3 shocks and superatv arms front and rear. Looks like everything clears, but will have to see if it rubs under compression. Camber needs adjusting too.View attachment 192362View attachment 192364View attachment 192365
Those were in the top of my list when I bought tires almost a month ago.
Russ989
Russ989
22,575
146,615
They are supposed to be preset these days but I can tell you that my fronts are off camber and need adjusting, my rear arms were spot on.
Hondoman
Hondoman
727
1,697
Texas
I removed the lift before putting the new tires/wheels on. I adjusted the camber some, but not enough. It's easy enough to do. Lift and wheel spacers change the camber each time you make a change.
56,798
Mine were way off in the rear. Had to come out 4 turns on the "preset" to get them squared up. Only had to come in 1 turn on the fronts. I'm still fighting alignment, but I think I'm close.
Russ989
Russ989
22,575
146,615
I need to adjust my fronts but my alignment is pretty good.
Napaul
Napaul
56
112
I keep coming back and looking at this thread. I really like the Super Grip K9 but I crossed them off the list because they don’t come smaller than a 30. I’ve taken long and numerous looks at the XTR370 but up until today I haven’t seen them on a Pioneer. They sure look good on it! How much pressure do you have in them, @Hondoman ? They look a little rounded. Do you have them a little over inflated to stretch them out or is that how they sit?
Hondoman
Hondoman
727
1,697
Texas
14 psi as they sit. Had 20-22 when I received them. They are more aggressive that I thought they would be (a good thing). I'm getting 30" tall on the machine at 14psi and 10.25" wide outside of tread to outside of tread as best as I can measure them.
20200326 193846
20200326 193630
Ridinfool
Ridinfool
36,145
386,040
Western North Carolina
I was considering those tires as well only in 28 not 30 because I still have all stock Dlux suspension, (at least till something breaks). I like the gold wheels I think that's what I'm putting on my camo buggy, now that I see them on your ride I'm sold... I think.😁
Reactions: Lady01 and Hondoman
Hondoman
Hondoman
727
1,697
Texas
Update after three rides:
These tires are meeting all expectations. Much more traction than the tensor regulators they replaced. I'm running most places in turf mode, vs 2wd lock or 4wd now.
I rode Mack's Pines/mocassin gap over the holiday weekend in wet rocky conditions without a hitch. They are a little heavy at 41lbs each, but the machine didn't notice too much. My low gear is out and I ran everything in high no problem. Was able to run 61mph on the highway (per can am commander speedo who was with me). No cuts or chunks of rubber missing. No flats.
Side bite is awesome when straddling ruts, tires just track straight. See side lug closeup here:
20200527 180919
Russ989
Russ989
22,575
146,615
I like those tires, I’d really like to see them in person as I’m sure the pics don’t do them justice.
