TALON 1000R REAR A-ARMS
SuperATV
SuperATV
1,249
8,727
Madison, IN
www.superatv.com
TALON 1000R REAR A-ARMS​
Link: https://www.superatv.com/honda-talon-1000r-rear-a-arms
  • Honda Talon 1000R : 2019+
Push your Talon to its Limits
Getting hung up on rocks and logs can put a damper on your day. Instead of getting your undercarriage caught or taking the long way around—ride over them with SuperATV’s Honda Talon 1000R Rear A-Arms. They’re bigger and stronger than your OEM arms and feature industry-leading adjustable pivot block for full camber adjustability.
Bigger Than Stock with a Lifetime Warranty
We use 1.25” tubing for these control arms, which makes them 25% larger than stock! The powder coat finish adds strength and protects against rust and premature wear, and they come with free bushings. Even though we focused on making these A-arms super strong, we didn’t forget to make them look good too. They’re head turners—their sleek, tubed design will make your machine stand out in a crowd.
And because we believe in our A-arms so much we back them with a lifetime warranty.
Industry-Leading Adjustable Pivot Blocks
These A-arms come with adjustable pivot blocks, allowing you to modify your camber as needed. This means you won’t have to worry about premature tire wear if you add a lift kit, shocks, or extra weight. The innovative design and full camber adjustability give you an all-around smoother ride, no matter what. We ship them to you preadjusted to stock specs and with free bushings and heims installed so you can get riding.
Honda talon rear trailing arm kit a arm only 01
Honda talon rear trailing arm kit a arm only 02
Honda talon rear trailing arm kit 5 1
  • Love
Reactions: Remington and CID
