Keller Ball Joints for the Honda Talon
SuperATV
SuperATV
1,236
8,601
Madison, IN
www.superatv.com
KELLER BALL JOINT​
Link: https://www.superatv.com/honda-talon-1000-keller-ball-joint
  • 4340 hardened chromoly steel construction
  • Two-piece threaded design doesn’t require a snap ring
  • Easily adjustable, rebuildable, and greaseable
  • Robust boot retaining ring prevents water intrusion
Bjk h t1000l 2a 3
Keller Ball Joints Are Tough
These are no OEM ball joints—Keller Ball Joints are just better. Put these ball joints through the absolute worst abuse and they’ll make it through. Their beefed-up two-piece chromoly housing eliminates the need for a snap ring making them virtually impossible to pull out. Upgrade your Honda Talon 1000 with the best ball joints around.
  • Two-piece, threaded design eliminates snap ring
  • Chromoly steel construction
  • Easy to maintain
  • Backed by a lifetime warranty
Designed for Maximum Strength
When our buddy Todd Keller made Keller Ball Joints, he wanted to make the toughest ball joint possible. He was tired of his OEM snap rings breaking and causing his joints to pull out. That’s why he designed a two-piece threaded ball joint that eliminates the need for a snap ring. The joint presses into the arm and the housing threads onto the back to make sure nothing can push or pull it out.
Made with 4340 Hardened Chromoly Steel
Keller Ball Joints are made with hardened 4340 chromoly steel housings and studs. Plus, the studs don’t narrow as much stock for extreme strength. All that makes them nearly impossible to destroy. And they’re greaseable and adjustable for incredible longevity.
Two-Part Design and a Lifetime Warranty
These ball joints are beefy as hell. That’s why we back them with a lifetime warranty. Go hard with lifts, jumps, and nasty terrain—you’ll never find a ball joint that can handle it better. Get Keller Ball Joints, lose the OEM snap ring, and unleash the beast inside your Honda Talon!
Jzallen01
Nashville
the lowers install the same way as uppers? Can’t find any videos on the lowers.
i just ordered some from you guys 😀
