Talon Power Steering Kit - SuperATV
SuperATV
SuperATV
1,250
8,732
Madison, IN
www.superatv.com
TALON POWER STEERING KIT​
Link: https://www.superatv.com/honda-talon-1000-power-steering-kit
Ps 3 82 400w 1
  • Reduces steering effort
  • Eliminates steering feedback
  • Compact control box for easier mounting and installation
  • No soldering required for EZ-STEER wiring
  • Sealed input and output shafts
  • Watertight control box and connectors
  • 400-Watt motor
Save Your Strength
Your Honda Talon is supposed to be a well-oiled machine—you shouldn’t have to break your back to turn it. If your rig’s steering is stiff or hard to manage, install SuperATV’s Honda Talon 1000 Power Steering Kit. The 400w motor makes it easier to turn big tires on tough rocky trails. You shouldn’t have to compromise your steering just because you’re rocking a big lift, portals, and big tires. This is an upgrade you don’t want to miss.
EZ-STEER is Easy to Install
Thanks to a watertight control box, you can take on any terrain in any weather with our power steering kit. That means you won’t ruin it when you get tires-deep in mud. It’s super easy to install too—there’s no soldering required for our EZ-STEER wiring. We include full instructions to get you out of the garage and back to work ASAP.
  • Honda Talon 1000R : 2019+
  • Honda Talon 1000X : 2019+
  • Honda Talon 1000X-4 : 2020+
208,029
  • 400-Watt motor
Save Your Strength
How many thousands for NTC members?
Vondy
Vondy
1,400
8,960
Houston,OH
  1. Talon X4
  • 400-Watt motor
Save Your Strength
  • 400-Watt motor
Save Your Strength
Will the display any errors after installing?
SuperATV
SuperATV
1,250
8,732
Madison, IN
www.superatv.com
I believe if you connect it all right, you should see the display error.
If you go by our instructions, you probably would see the display error because we kind of skip over some stuff to make it easier.
@PaulF connected the yellow and green wire when he fabbed his up, and didn't not get the display error.
This is from @PaulF 's thread on his installation. Great work,, Paul.
1658346313541 png
