Talon X and R Heavy Duty CV Prop Shaft - SuperATV
SuperATV
SuperATV
1,236
8,601
Madison, IN
www.superatv.com
TALON 1000 HEAVY-DUTY PROP SHAFT —RHINO DRIVELINE​
Link: https://www.superatv.com/honda-talon-1000-heavy-duty-prop-shaft-rhino-driveline
Prp03 002f 1 1
Rhino Driveline Shaft:
  • Shaft diameter is .5” larger than stock
  • Shaft wall is .120” vs stock’s .088”
  • Made of 4130 chromoly tubing (stock is plain carbon steel)
C-Series:
  • Uses a strong and versatile CV joint
  • Made of 4130 chromoly steel
  • Sealed for any riding environment
  • No vibrations, no wobble, no maintenance
  • Honda Talon 1000X : 2019+
  • Honda Talon 1000R : 2019+
105,378
Just bought mine and don't wanna tear apart if dont have them if i need them. Is it just buying rebuild kit or?
Your question will be answered shortly.
Welcome from the once great state of Commie run Michigan!
We’d kindly prefer that you start a new welcome thread with your Info, and info about your rig and pics of your machine. These guys get upset when u dont provide pics.
So In the mean time….
PICS OR IT DIDNT HAPPEN!
906UP
906UP
13,017
121,364
da Yoop
Do you have to use carrier bearings?
No carrier bearings on the Talon
Not sure I understand the question.... this is a replacement driveshaft that uses CV joints instead of U-joints.
105,378
I just meant the carrier bearing rebuild kit on superatv but no bearings needed answered my question thank you!!
Since your new gonna teach you some forum etiquette.
When answering someone, hit the “reply” button under there question then answer under the box. (See above) Or type there name like this @Draggeezy in your response. Otherwise they May never see that you did. ;)
Pro tip:
Dont forget that intro thread and pics! #POIDH!
