The next project
kandt
kandt
126
762
Bluegrass state
Guess I am looking at another project. Not sure I need another one but this was in a barn out my back door. Actually drove the PK5 to pick it up down the road.
Hoping to get it to run. 85 model big red.
BC01EB75 492A 4C67 A7BE B6F8ADA349FF 34F446F4 CBCB 4F6E 8840 32826C68693C A362194C A4CE 4DF4 AF90 A89F3EFEBB6B
DRZRon1
DRZRon1
841
2,685
PA
way cool barn find, it will run.....
as you may know - never ever take your feet off the pegs, ran my leg over many times trying to steer those things in the 80's...
kandt
kandt
126
762
Bluegrass state
Thanks for the advice. No plans not to use the foot pegs lol. It was my dads cousins. The only memories I have of it was in 87 I killed my first buck on the creek of our farm. We used it to haul it out and the buck slide down and the antler punctured the rear wheel. Going to be fun trying to get it back to running.
kandt
kandt
126
762
Bluegrass state
We went through it today. Going to order battery, oil, filter, air filter, and spark plug. Thinking it’s hopefully a diamond in the rough.
this was about 30 minutes of cleaning on the fuel tank.
2EF3F059 8358 47ED A4AC 37422EFE497C 0E63BC9C 60D3 4A44 86CE 273B6821B670 93FDE529 5421 4BA2 9882 52E0D1504184 1E15B78D 33AE 4F45 85C9 6E422E582CDC 29E12F01 5CFF 40FD BC6B 4249E8E71A7E
kandt
kandt
126
762
Bluegrass state
Good find!👍 Is that is the original seat!!!???
Silver- here a few pics of the seat. Little wet rags and some armor all. You can see the only flaws in the rear of the seat. A chunk missing and a run line and below the rub line is a little loose area of fabric. Outside of that it is pretty solid. Think it is original seat. Have no reason to think not.
CC1EF412 9C48 4087 80CA 8886B773A41E 3AD1393B E1BA 4A7A 94C3 4438DB53367E BDBA6339 77E8 49A2 893F D0608F898502 93C3CCEC 3E1E 40E5 86E9 3FA924C35971
lee
lee
Village Idiot
2,327
13,031
Springfield Ohio
The Big Red was awesome.
Easy to ride, torque like a tractor (compared to the 2 strokes I favored).
And very capable.
No extra BS like an extraneous 4th wheel.
Leverage 3wheelerworld.com for info and a line on parts.
kandt
kandt
126
762
Bluegrass state
One thing I am missing is the side plastic panel on the right side. The one that goes over or around the kick starter. If anyone has any leads on one pm me. If we can get it to run, I will be looking for one. Thanks.
Rayger143
Rayger143
2,708
23,426
Winfield, BC Canada
kandt
kandt
126
762
Bluegrass state
Well it’s getting cleaner. Excited to put it back together. This coming weekend planning to paint all the racks, change oil, spark plug, air filter, and front tire. But the plastics turned out pretty good. If anyone can locate a right side panel (OEM) I may be interested.
DDF2A62E 48F8 48BC 8C85 E00A56D6690D 74719AE4 1E2D 48F3 A8BB 1DC8123D68CB A9318A93 BC05 4A9E AF8B 0875EFA7B5FB 629EF7F6 C971 48AA B896 A0C8569FC0E4 6D4D8E29 68EF 4FBE A856 EBA75141A87D A60655D3 BA78 4D3E AC05 64E249BFDEC5 34023910 CB8E 47E4 A52A 78D78B1477CE
kandt
kandt
126
762
Bluegrass state
New spark plug, air filter, oil/filter, and rear diff oil she is running. Push start just getting a click at the selenoid. Kick start got here running.
After a few she didn’t let out on rev. It will rev down sometimes but hold rpm’s fir extended time. I could pull on throttle cable housing and it would have some affect on rpm’s. Not sure if carb needs cleaned or replace a throttle cable. Any suggestions? Carb cleaning may be outside my expertise lol.
DRZRon1
DRZRon1
841
2,685
PA
congrats, you got this far and have fire, so imo, the carb cleaning would be next....
watch some youtube videos if you are unfamiliar, it is not so bad and just cleaning the jets/passages/slide.....you will also be able to see if throttle cable is working as well.
id squirt some penetrating down all the cables as well
DRZRon1
DRZRon1
841
2,685
PA
also look for cracked, dry rotted rubber boots that clamp to the carb, I have a 99 wolverine in the garage that got dropped off, rubber boot to intake has holes in it - weird
kandt
kandt
126
762
Bluegrass state
Update- the new starter fixed the push start troubles. Been touching up frame paint. Carb is last thing I plan to do. Working to get it back together. It’s in several pieces. Bought some seals and reworked front forks. New fluid and fresh look. Now just piecing it back together. Work and a dang respiratory deal has hindered much work. Pretty happy with the front forks. Before and after.
AFFCE22B 47D5 4834 8C8F E52651CD37A1 ADB55724 9B84 445E 882A 19D8873293C7
