Tire Pressure PSI
TrailTamer
0
Maintaining proper tire pressure is important with any vehicle much less your side by side or ATV. My experience with ATV's has me accustom to low pressure tires around the 4-5 psi range. With such said do you think the Pioneer will run the same low PSI tires? One would think that since it is a heaver machine that Honda would recommend increasing the PSI to a higher level.
admin
admin
Your club! I just turn it on!
317
You are correct, Honda does recommend increasing the PSI above what you may be accustom to with a ATV. Maintaining the proper pressure is important. However most important is maintaining the proper balance between the left and right sides of both the front or rear. Having odd or off pressures is dangerous and you could be seriously injured or killed if you loose control.
When checking pressure it is important to check at what they call the tires "COLD" point. This point would be before you even take it for a small ride around the parking lot. Once the tire starts to roll the pressure builds and will give a over-reading compared to its COLD point.
Honda recommended COLD pressure levels:
Front: 10 PSI (70 kPa), Under heavy load maintain 10 PSI in front tires.
Rear: 12 PSI (80 kPa), Under heavy load maxim 18 PSI (120 kPa)
Have fun and stay safe.
atvsnowman
atvsnowman
23
I run 10 in my ATV now. It calls for 4 I think. So I'm sure 12 will not be enough for me.
Stumper
23
83
Bandana, NC
My New to Me, 2022 1000-3 manual says 18 psi front and rear. That seems high to me and higher than what others are quoting for these machines. Did Honda increase the recommended pressures for 2022? Tires are stock Armstrong 27"
Mopower58
Mopower58
CST is the Best!
70,610
647,688
Crystal Springs,Ms.
I’ve got 28” Big Horn II’s,9’s in front and 11’s in back,and when I was at the 2022 TO I ran 14 psi to prevent a pinch flat. Now I run 12 psi front and rear. I would adjust the air pressure to suit your particular riding environment. Slow, rocky,hill climbing less psi and flat trail riding more psi, making sure the pressures are even side to side.
106,604
Ok, surprised @Mopower58 didnt let you know this lol. But looks like he was kind enough to answer.
This is an 11 year old thread. The last post before you posted was 11 years ago as well. Always try and look to see 1 how old the thread is and 2 when was the last time the person your responding to (always hit the reply under the post your replying to as well)
For example, the OP hasnt been on since 2013 and the the other guy since 21’ odds are they aint gonna see your post. Best off to start a new thread at that point if u cant find your answer in the search FYI.
  • Wow
Reactions: CID
Stumper
23
83
Bandana, NC
  • Haha
Reactions: Remington
