P1000 Tire Pressure Question
Travis R
Travis R
135
441
Southeast Louisiana
Hello,
My 2016 Pioneer 1000-3 EPS has 30x10x14 High Lifter X Comp tires. How many pounds of air should be in each tire? How much pressure are y’all running?
I need it to be a smooth ride because I have a bad back. I mainly ride on black top/asphalt and gravel roads. I don’t go in much mud, except to my deer stand.
Backwoods
Backwoods
33,087
339,524
Douglasville ga
Hello,
Try the sidewall recommendations and adjust from there
Mopower58
Mopower58
CST is the Best!
72,602
663,287
Crystal Springs,Ms.
I’ve got 28 inch tires on 14 inch rims. I ran 14 psi at the TO to avoid pinch flats. Let them back down to 10 psi around here. @Backwoods pretty much runs asphalt and easy trails, he would have a better idea.
Backwoods
Backwoods
33,087
339,524
Douglasville ga
My max is 35 psi, Min 20 psi. I run 15 in them on bead locks. Every tire and everyone is different. They are also 10ply DOT
0AE9A94E A720 4751 8FEA FDAE6D6CF9DC
seijirou
seijirou
84
897
83
Kaufman, TX
  1. 1000 6 Crew
Hello,
You want fewer pounds than @Backwoods is taking in his... backwoods any given evening or they'll pop, but more pounds than he's giving the ladies any given year. Start at maybe 25 and go from there.
Backwoods
Backwoods
33,087
339,524
Douglasville ga
You want fewer pounds than @Backwoods is taking in his... backwoods any given evening or they'll pop, but more pounds than he's giving the ladies any given year. Start at maybe 25 and go from there. Did I mention I lick sticking things in my prison wallet. I’m also available for hook up.
Buggyman
Buggyman
36,451
309,361
ne. ohio
There are a few variables when it comes to tire pressure. If you are adding it to the bottom you will need more air to support the weight. If you are adding to the top you can run less and get the softer ride you are looking for. really, it's trial and error but there are about a 1000 threads on it in the search bar up top. JK TGIF
Backwoods
Backwoods
33,087
339,524
Douglasville ga
There are a few variables when it comes to pressure. If you are adding it to the bottom you will need more to support the weight. If you are adding to the top you can run less and get the softer ride you are looking for. really, I also am available to meet for hookup.🍆🍆🍆
You people are sick
O
ob1jeeper
97
279
Arizona
I'm in the same boat as you are with a 2016, similar tire/wheels, and a sore back. I run 8-10 psi, EVERYWHERE I take it, and have NEVER had a single tire related issue for a tad over 10,000 miles... PS: the ride is WAY smoother at this pressure and the tire wear is not an issue. Still running the same tires that came to me with, & the original owner of this unit also recommended this pressure... ;)
PJon
PJon
782
3,162
Arizona
I run 10-11 psi in mine with bead locks. BFG KM3’s 28x10x14. They run quiet on the little bit of time on State roads and will crawl through loose rocky hills with no tire spin.
Reactions: Backwoods
HBarlow
HBarlow
1,614
5,998
Daniels, WV
The correct inflation pressure for each tire, regardless of size, for normal driving, is the pressure that will allow the tire tread to make full contact with the road surface. This can be easily determined on blacktop by driving the machine through a wet patch and then to observe the tread footprint made by a wet tire as it rotates on dry pavement.
Different or lower tire pressures are usually preferred in sand or other conditions.
