P500 Torq Locker Install
Bad Company
Bad Company
49
139
Wartburg, Tn
I did a series of Torq Locker Install videos for the P520. It's a 4 part series and I have 2 parts up on YouTube now, there will be a new video up each Saturday until all 4 are posted. I'm not a professional youtuber, in fact these were my first videos ever, but I'm learning.
11,361
84,635
Good video! Good explanation of the 4wd cable removal. Yep, the 4wd sensor wire connection pulls off. No need to rotate the wire/unscrew the sensor on the drivers side diff (~13:00), glad you noticed it and mentioned it later at 20:00 to help others.
Bad Company
Bad Company
49
139
Wartburg, Tn
Thanks Mudder! I try to help other not make the same mistakes I do. Other videos I watched did even mention the 4WD sensor, just said remove it. My videos will be long and drawn out maybe a little bit, well a lot... But hopefully they will help someone out.
Have you put the lockers to work much BC? I’m curious if there’s any popping noises coming from them when they’re engaged and working….?
Reactions: KyGal83
11,361
84,635
I only hear/feel a slight clicking via the steering wheel when making sharp turns on the concrete driveway. Much less an issue than the rear tires scrubbing when turning on the concrete due to the solid axle. No regrets with the locker.
Thanks Mudder. Is it the same as it’s been since day one, or did it quiet some with age and use? My tech seems to think it’s exaggerated, enough to contact Torq Masters and discuss it with them before releasing it to me? Mine is on the Talon too, don’t know if there’s going to be any differences…..🤔
11,361
84,635
Well it is a hard treated metal ratchet with spring design so there will be some contact, more so under torque in 4wd on hard surface (which I never do). Compared to a P500 without it, yea, but still nothing compared to that clunky rear P500 diff. I also changed to heavier synthetic diff oils.
Reactions: Montecresto
N
NeHunter13
21
104
Nebraska
How does the front act when only in two wheel drive and on a hard surface? I understand the shaft wont be turning to the diff but does the front act differently from stock when in two wheel drive? Thanks!
11,361
84,635
I notice no difference, and have Power Steering installed also. Check out AMR’s testing video, especially around 9:00 on turning diameters. No regrets with the locker whatsoever. Hope this helps.
O
oldfortyfive
596
1,321
Illinois
If you don't have power steering (I don't) you have steering wheel stiff points as you turn. They vary in stiffness and location...always changing. You may not feel any going one way then the other way need two hands. If you're going fast, turning and hit stiff spot it could get you into trouble if you're not ready for it. I assume the stiff spots happen when the locker ratchets.
The Talon has a weak power steering system, so there is some concern on steering. Although, I’m not too worried about going fast, I’ve had the lockers installed to assist me in rock crawling and climbing very steep trails with loose rock at great elevation. I just hope the lockers answer to the trouble I’ve had without them….🤞
O
oldfortyfive
596
1,321
Illinois
I'm not doing any high speed running or much snow plowing so I haven't had much interest in power stressing...maybe if I tried it.
The Green Goat
The Green Goat
1,783
12,693
Torq Locker is amazing. It makes these little things nearly unstoppable. Highly recommend plus power steering.
Half pint
Mississippi
do you have to completely disassembled the shift cable after pulling the clip out
Half pint
Mississippi
Do you have to completely disassembled the shift cable after removing the clip?
The Green Goat
The Green Goat
1,783
12,693
