Trailer size for talon
Dan1225
Dan1225
14
58
Pleasant hill
Hey there new talon owner here need to know what size trailer everyone is running in the market for one the one we had for our pioneer won’t do the trick any help is awesome. Thanks boys
34,174
I’m using a 14’ Big Tex tandem axle trailer with spring assist gate…
5,034
22,504
This is my '20 (pre theft) sitting on a 14' trailer with 250 lb. tongue weight. If you have the room to park it, longer is usually better.
1632800072233
This is my replacement '21 with 2 spares and a bed extender, same 250 lb. tongue weight.
1632800300797
And this is why longer is better, my traveling setup -
1632800371984
HBarlow
HBarlow
1,618
6,010
Daniels, WV
I agree with CID above. I have a Big-Tex 12' single axle. I chose the 12' over a 14' because the shorter trailer is easy to store in my garage when not in use which is 98% of the time.
The trade-off is the 12' deck leaves very little open space in front of and behind my P1K3. This makes it a little harder to strap it down when towing
The trailer buyer can choose between easy to store when not in use or easy to strap your machine when towing.
I think you'll need at least a 14' trailer for a Talon.
IMG 1814 IMG 1815 IMG 1816 IMG 1817
105,933
I have a 16’ tandem axel. The tandem is the way to go and they will have trailer brakes std on them and are a must them pulling a machine especially with gear imo. They do make some pretty nice single axels like above capable of pulling the weight but your limited in capacity and believe me, there will be times you will push it.
old pics but you get the idea. One has a gas log splitter on it.
39E2E0D2 9C05 4FC4 BB66 45180BCD34AF
43A0701B 3AC9 4182 ACD5 818CBFC09970
Welcome to the forum BTW.
let me get this streight, you had a pioneer and now a Talon this is your only post since joining in April and no pics! 🤨 We showed you ours and now you show us yours! Wait that sounds bad lol well you get it anyway…
PICS OR IT DODNT HAPPEN! 🥳
34,174
old pics but you get the idea. One has a gas log splitter on it. View attachment 297352View attachment 297353
Yep, the tandem is so much easier to pull and back, and not near the difficulty or danger when you have a flat….
Barracuda
Barracuda
78
410
53
Washington state
  1. Talon X4 LV
  2. w/Turbo
I am using my enclosed trailer that I have had for quite a few years. I bought the Talon ( a 2021 1000X-4 ) before I realized my trailer wasnt tall enough...
I had to improvise to find a solution;
1635087833507
7254DCBF BEAA 4EA3 ACD6 52908B6224D2
685135FD 4E48 4B9A B8A7 BC5A5C527965
3126269A D039 44DF BAFA 49E78EF89962
E4EA7955 DCD0 4F27 B7DB 0EEF6F5B2E4E
It did require spacers to be used and I only recommend using for loading and unloading in the trailer but it saved me from having to buy a new trailer...
CEA9DCE2 27D8 410A 8E93 18CD32B49601
Barracuda
Barracuda
78
410
53
Washington state
  1. Talon X4 LV
  2. w/Turbo
What the smallest tire I can run????
Don’t see that too often! 🤣
The brake rotor diameter is the limiting factor - I think the wheelbarrow tires I have are about 14inches and I do not drag (maybe an inch and a half to spare(?).
It does look funny, but it works pretty good!!!
NTCPrezJB
NTCPrezJB
President of #NTC
100,755
900,258
Canton, OH
Someone did wooden wheels and posted a thread about it. I think it was a P1k-5 though.
Todd627
Todd627
56,306
615,238
MI
34,174
View attachment 301273View attachment 301274View attachment 301275View attachment 301276View attachment 301277
It did require spacers to be used and I only recommend using for loading and unloading in the trailer but it saved me from having to buy a new trailer...View attachment 301278
Wow, what a major inconvenience. But if replacing the trailer isn’t an option, that’s a very enterprising solution….😎
