turn signals
K
kdspilker
I have a 2022 Pioneer 1000-5 which I would like to add turn signals to. Is there a system which will turn off the headlight on the side for which the signal is flashing just like the newer vehicles do?
I have a Forest Edition which comes with the front brush guard. Seems like the guard may be in the way of some of the front turn signal lights.
Also, is there a system which will flash the brake lights when applying the brakes instead of the normal "brake light on" when the pedal is pushed?
Reactions: Buggyman
Buggyman
Buggyman
34,892
297,817
ne. ohio
welcome from Ohio. I have not seen a system that will do what you want but the turn Pro kit that is sold here in the club store is a very well made and truly plug and play signal kit.
107,347
Welcome from Michigan.
First and foremost is Rule #4 Pics. We like pics of your rig for verification or you get…
Pics Or It Didnt Happen!
also, never heard of a State#68310, is that a prison? 🤣
Turn pro is the kit you want. I have them in both my rigs. You will need to choose the one that uses your brake lights for signals. This can be found in the club store.
also, there is nothing that turns your headlights off. Buy a Jeep or Bronco if you want that 😂 the front signals are bright enough to see.
GRANITE
GRANITE
People Dying to come see me!
1,100
5,550
Brookville, Indiana
I have a blue '22 deluxe and I added the front bumper like yours. I did the Turn Pro kit from club store and works great. I placed the led's in plastic in opening of bumper. works perfectly....I don't have pics however but can get you some
Plowboy1466
Plowboy1466
290
1,453
Ashland, Ohio
I bought the XTC kit. It was plug and play, and now they have an auto cancel one. The Turn Pro sounds pretty darn good though.
HondaTech
You could add a back off module to the brakes to achieve the flashing effect.
But the headlight off thing would require some wiring and relays to achieve.
Reactions: Buggyman
