Viper 4500 Winch
E
eolesen
70
251
53
People's Republic of Illinois
0ced6ceb26fcefa6d022a95d9d7f9816
Looking at the Viper Midnight and X-Bull for a 4500 synthetic.
Any opinions on either brand?
This will be used on a 700-4D, mostly in the Obed Scenic (TN) and rail trails in WI/UPMI.
Admittedly, the price of the Viper is pretty appealing right now and it's out of stock on the club store otherwise I would buy it here.
Scoop
Scoop
4,206
15,731
  3. Talon R LV
Never heard of XBULL.
XBULL is 1.5 HP
MA is 1.8 HP
MA has 1 yr warranty on winch and 6 mos on rope. Couldn't find XBULL warranty.
MA is cheaper.
Does the MA include the wireless remote like the XBULL? There is a picture of it, but it's not specifically listed as included. EDIT: I looked on the Motoalliance.com website and the 4500 models (synth and steel cable) do include the remote, but the DASH rocker switch is NOT included - it's an upgrade if ordering from their web site. It comes with a handlebar switch, though.
In that price range, I'd bet most winches will be about the same.
Between the two, I'd go Motoalliance Viper Midnight..
I have a Motoalliance Viper V2 frim the Club store on the Talon. It's solid AF.
Russ989
Russ989
22,560
146,463
I’d get the viper.
63,402
Both I consider entry-level winches.
I just added some back to the club store.
This entry-level winch is transitioning to include wireless remotes as part of the package.
You will find some with it included, and others without.
If you order, I can make sure it has one.
Reactions: Scoop and JenElio
Scoop
Scoop
4,206
15,731
  3. Talon R LV
^ I think the store is offline, @Hondasxs
Scoop
Scoop
4,206
15,731
  3. Talon R LV
Must have been short lived. Both the link and going to the store directly resulted in an error from the server. All good now though.
E
eolesen
70
251
53
Got my Viper today from @Hondasxs including the wireless remote. Shipping speed was great considering I placed the order on Monday and had it this afternoon.
First thoughts on the kit:
  • The red/black wires are only 2 ft long
  • The blue/yellow wires are 5+ ft long
  • The DPDT switch for the winch doesn't fit the pre-cut openings on the Honda 700 dashboard
  • Mounting holes on the generic winch plate mount line up with the Viper's bolt pattern
  • There's plenty of room between the electrical leads on the winch and the bumper/frame (which was a concern based on some other threads here
  • Fairlead plate lined up as well, although there's a ~3/16" gap between the bottom of the aluminum plate and the opening on the mount
The length of the red/black wires is impractical on the 700, as the battery compartment is under the passenger seat and not under the hood like the 1000. Aside from the color coding being off, I'll swap the blue/yellow wires with the red/black wires, and re-use a DPDT switch from another project for the dashboard mount.
Other than that, it looks like a one hour installation if that, which I'll save for later in the weekend.
E
eolesen
70
251
53
Yeah, you're not wrong on that.... but it's because I got side tracked?...
Used the drill press with a step bit to open up one of the center mounting holes that won't be used by the winch, and then bolted down the front 2" receiver. That meant removing the bumper and bracket...
But it's what I wanted - a winch -and- a front receiver for easier positioning of my trailer in the back of our property... can't think of a case where I might need both, but it could provide a hard point for anchoring a snatch block.
Now I need to break out the stick welder and put a bead across the front edge to keep it in place.... and all this before I've turned a single socket on the winch attachment bolts....
Before drilling out:
A57282323d48ec5bb64c7a6207613eed
While drilling:
3ea0827d12bd89fefdb38e753809bd94
Drilled out:
9565df6b145e511c4ab3e783c20fb2d6
Bolted on:
A131d988caea802325a581c394e5939378d5bbf2d29d6398a9bdbf01f3c99c29
Nasty ass welding job later, I finally got around to mounting the winch:
466805363a3956f00f254a351777491086f047723f999c5d47ab185242510c97
That receiver should be good enough to push a trailer around as needed, or to hold a hitch-haul with a cooler or the canoe T... the shackle mount will make a good place to hang the hook if nothing else.
E
eolesen
70
251
53
When your football team is losing, that's a good time to take a walk outside and work on wiring....
Beb78ac309dd5e38c0b7235873b715df
I did a dry run of the wiring just to discover the power tap to the switch didn't actually have power... Rather than rely on the inline splice, I clipped the feed wire, stripped both ends, and twisted those plus the tap wire into a crimp cap (sort of like a wire nut, but permanent).
That did the trick, so I took everything apart again, fed the wires where they were going to live, and then locked down the solenoid to the inside of the hood.
5789a40cc7603121efc8feb8abfda79b
In case there was any doubt.... this is what I'm using the front ball for: maneuvering the trailer into a parking spot along the side of the garage. It's more or less convinced me to do the same on my F-150 for parking the travel trailer (something I've wanted to do for a while but just haven't gotten around to yet).
While I don't have trouble backing it up with the truck or the Pioneer, it's definitely a lot easier to push the trailer with a good view...
3fb91fb4c1dea02de79c24500e6ba525 A55ffe7e46c423fa5c2f809ea1eb1c78
Sent from my SM-S911U using Tapatalk
Reactions: Scoop and Backwoods
E
eolesen
70
251
53
Last comment on the long and drawn out install... I hooked up the wireless remote, which at first I wasn't sure I'd use, but am now thinking otherwise if I ever have to do a solo recovery....
The wiring instructions for the wireless remove are reversed -- the black and yellow go together, and the white and green go together. When I hooked it up per the instructions, the out and in functions were reversed on the remote. Not an insurmountable fix, but a little annoying in 40 degree weather.
Hopefully this is a little like insurance -- all the work/money won't be necessary anytime soon.
155,419
Heads up on that wireless remote, some are known to draw down the battery even when not in use.
E
eolesen
70
251
53
Good to know -- it's all on the keyed power feed, but it's easy enough to put a line disconnect in place and only connect it when needed...
