P700 What is the Diameter of the Roll Bar
G
Greg1881
Montana
Need to get some side mirrors for my 700. What is the Diameter of the Roll Bar and do you have a recommendation on a brand or mirror.
Thanks
Greg
livefromthetree
livefromthetree
It was a damn good ride. Seriously good.
466
1,309
Mount Vernon Indiana
Thanks
Greg
I have these and they work as intended although I did have to make better shims to fit because the shims they come with would not tighten down. Used a cut up rubber bungee cord.
Also, thanks for the reminder. I took mine off a month or so ago and forgot to put them back on :D
caverat
101
193
Montana
If you only want to have to buy your mirrors once spend the money and get seizmik I went though 3 sets before I finally did some only held up 2 rides. The seizmik mirrors have been great and no problems at all
BillC
6
7
Pa
Don't buy these
kemimoto UTV Side Mirrors they fit the roll bar fine but you can't get the mirror itself tight enough to not move.Have good reviews on Amazon but the ones I have don't work.​
MTrockSlinger
20
76
Montana
Yeah I just bought a cheap set called “Bevel Engineering” and they won’t stay put on the trails or even high speed bumps on gravel roads. Had to use my own custom cut rubber shim to even get them mounted securely to the roll bar because the shims it came with were not enough.
BTW: the roll bar diameter on my 2021 700-4 where mirrors mount is 1.625”
But front bumper is 1.75” if you want to mount anything up there
Tim-1000 XT-R
Tim-1000 XT-R
283
899
Oakdale, MN
They have a lot of choices on their site. Which ones did you buy? Thanks
