P1000 What size tires for your Honda Pioneer 1000?
What size tires will you run on the P1k?
  • 26 inch or smaller
    Votes: 1 0.3%
  • 27 inch (OEM Size)
    Votes: 58 16.8%
  • 28 inch
    Votes: 155 44.8%
  • 29 inch
    Votes: 35 10.1%
  • 30 inch
    Votes: 87 25.1%
  • 31 inch
    Votes: 7 2.0%
  • 32+ inch
    Votes: 3 0.9%
  • Total voters
    346
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
Monster Mayhems 30-10-14o_O
Reactions: BWAF
265,708
STI Roctane XD 28" x 10" x 14" all the way around. I have had very good luck with Roctane's in some seriously sharp rocks and been lucky to not have had a flat yet.
ElmerFudd
ElmerFudd
54
91
What size tires do you plan to run on your Honda Pioneer 1000?
Thanks.
Poll viewable on the website!
Just wondering, cause I have no experience with putting different sized tires on stuff, does radically changing the tire size change gearing and if so how? Also, does it void your warranty?? Thanks
Reactions: BWAF
63,610
@ElmerFudd,
Welcome to the club. If you have any nooby questions we would be happy to answer them. Start a thread and ask away.
Gearing - Yes, it changes the final "to the ground" gearing ratio. Makes it taller allowing the SxS to go faster by a tad. This will also raise the lowest gear making it harder to turn when under a load. But the biggest advantage is the added ground clearance along with a smoother ride that larger tires provide. With the P1K having a manual and low range it will not be a issue.
Warranty - Possible, It really depends on your dealer perception of what you do with your unit. If they consider you abusing it then yes. If you just go up from a 27 to a 28 they most likely want say anything. but if you jump to a 30+ then they might. "The drive train is not build for 30" tires" they will say.
ElmerFudd
ElmerFudd
54
91
Thanks for the quick reply. I am very interested in the new 1000 !! Rangers rule the land here in Northwest Colorado. Best there is right now for guiding hunters. Quiet, can get two hunters in one buggy, can put dog box in the bed, load whole elk in back, etc. Would really like to be the first in the neighborhood to have the new Honda. I don't think Honda realizes the market there is for the hunting type crowd.
bobbyhill
bobbyhill
Junior Moderator
1,271
952
Smithfield, VA
Welcome to the Club @ElmerFudd !! and happy hunting!
Reactions: BWAF
chadbo
chadbo
Mama tried
2,044
5,658
Seminary , Ms
Would rims from my rincon with independent rear work on the new Sxs 1000. I thought Honda was the same with the exception of independent rear to a strait axle but to order aftermarket now ... Is there more details to it
Reactions: BWAF
chadbo
chadbo
Mama tried
2,044
5,658
Seminary , Ms
Ya they will.
Or at least my oem Rincon wheels fit my P700. P1k should have the same lug pattern as the P7 so I would say yes, they will.
Ok thought that was prolly the case .May keep some mud tires on 12 in rims
Reactions: BWAF
Wasn't sure but did we decide a true to size 30 x 10 would work without a lift
From a side view assuming the 27" are ACTUALLY 27" yes, but that is a big assumption to make knowing how tire manufactures like to be "inconsistent" and occasionally flat out lie (if it says 25" and it only measures 24" that's a lie IMO, 25" and measuring 24.75" that's inconsistent) about the actual tire size. Not sure about tire clearance when turning or compressed. Someone will need to get ahold of a 1000 to find that out.
looking at you BigH
Reactions: BWAF
265,708
Ya they will.
Or at least my oem Rincon wheels fit my P700. P1k has the same lug pattern as the P7 so I would say yes, they will.
I was curious if Honda went to a bigger diameter wheel stud on the P1000 vs, the P700 & P500, especially since the bed weight rating, towing capacity, & vehicle power were vastly different from the P500 to the P1000 but they all use the exact same part # 90113-SA0-006.
I would think a machine that weighs 700+ lbs. more not to mention hold 5 riders vs. 2 would need a tougher setup (P500 to P1000). Guess I don't have to worry about breaking a stud on my P500. :D
Reactions: BWAF and Cr250r
265,708
The same size studs are used on small cars that weigh 3500lbs, wouldn't think it would need to change.
I suppose so, guess it is typical of how Honda overbuilt much of the machines to start with that as they evolve the parts are already designed to handle it.
Luketheduke
Luketheduke
16
Washington state
Was thinking about putting 30" tires on my up and coming p1000-5 mysef, but was wondering if there is a way to adjust the speedo so I'll know my correct speed?
Probably not I would hazard a guess that it is calculated in the ECM like on the 500/700. Unless Honda has allowed an adjustment via the gauge cluster (which I highly doubt as it would encourage using equipment other than factory and open up warranty coverage issues for them) you're not going to be able to adjust for tire size.
Using a GPS app on your smartphone would be the cheapest way to get your real speed.
Welcome to the forum @Luketheduke
Reactions: BWAF and pct
TOOLOUD
TOOLOUD
261
155
Benton,La
I will be using my 28" radial outlaws to start with and then maybe go up to 30" radials in the near future.
Reactions: BWAF and utvmi
