What wire is everyone using for accessories?
BlackCSVT
BlackCSVT
22
27
Vail, AZ
  1. Talon X4 LV
Hi,
I’ve got a tons of stuff to install that’s just been sitting in the corner. Part of that is 8 set of lights to install. What wire is everyone using for lights? Is there any pre-mesh installed wire spools out there, or a higher grade of wire with off-road type insulation/protection?
Coming from a car stereo background I used to use Stinger or KnuKonceptz copper wire, but the insulation on those is pretty soft, and I’d be worried about damaging it in the AZ desert.
Reactions: TxDoc
TxDoc
TxDoc
1,677
5,812
TEXAS 🇨🇱
photos.app.goo.gl
Wire gauge will depend on voltage (12 volts in this case), current (in amps) and run (length of the wire carrying the current).
This article will help you understand and has a chart showing what wire you will need.
Good to remember:
Ohm's Law (E = IR)
E=voltage
R=Resistance (of the wire to the flow of current)
I=Current (in Amps)
Easy to remember:
I=E/R
The Indian sea the Eagle over the Rabbit
E=I/R
The Eagle sees the Indian over the Rabbit
R=E/I
The Rabbit sees the Eagle over the Rabbit.
Amps=watts/volts
I you see a light or light bar rated in watts, divide that by 12 to see how many amps you may be looking at.
****Many lights have overrated specifications ***
But, most quality switches can't handle over 20 amps and you'll need to use a relay. That's a switch within a switch. It lets a switch, even activated, access current from the battery and it doesn't have to pass thru the switch, possibly damaging the switch.
I don't know if this helps or is a case of TMI
5,096
22,919
Hi,
There's a switched hot plug above the steering column that most of us used, it's under the hood/hood cowl. The club store has a pigtail made for it.
ODAMO
ODAMO
1,177
3,206
Good to remember:
Ohm's Law (E = IR)
E=voltage
I=Current (in Amps)
Easy to remember:
I=E/R
E=I/R
R=E/I
Amps=watts/volts
The rabbit comes out of it's hole, goes around the tree, and then goes back down it's hole.
BlackCSVT
BlackCSVT
22
27
Vail, AZ
  1. Talon X4 LV
Thanks for the reply’s. TxDoc, I actually use those formula’s for my day job quite often when calculating total load on pool/spa systems.
CID, I have the XTC 6-switch controller for all the accessories, and a 2 way split for the blue plug incase I need to add more relays in the future.
I should probably be more specific. Im asking what brand of wire are people using, i.e. brand “XYZ” because it has foil between its double insulation, etc. or brand “ZYX” because it comes with the mesh sleeve already on it…
13,477
66,519
Any decent automotive primary wire will work for you.
Look into TXL, GXL, SXL variations. They are very similar, but different insulation wall thickness. Each is typically an OEM spec for any of the big automakers.
DRZRon1
DRZRon1
896
2,916
Auto wire, I use MTW, I put it in the black plastic wire loom or if it’s winch wiring, take air hose, split it down the middle stuff the cables in
Scoop
Scoop
4,285
16,070
  3. Talon R LV
I only use pure copper wire (solid or stranded). No copper-clad aluminum. Especially if you are soldering.
Reactions: TxDoc and Smitty335
L
LarryAmboy
894
1,979
Castalian Springs, Tennessee
Hi,
Marine grade wire like Ancor with shrink tube crimps
Joe_none
60
224
NC
Silicone insulated wire and adhesive shrink wrap. I like the higher temp rating as some things route near the engine/exhaust,cooling system. The adhesive also helps keep the water out with the shrink wrap.
