winshield foam sealing gasket missing
W
williamdean
12
I washed my pioneer the other day and noticed that a piece of the foam gasket between the honda brand windshield (hard coat scratch resistant)) and the frame is missing. Asked my dealer he said he could not get. I know hopefully that someone here will know where i can order it. Thanks PS you all should check it out, mine comes off to easy when i find the new stuff i will add a little silicone to it.
TandT
TandT
357
21
Newark, Ohio
I installed the glass full windshield and the seal on the bottom on both sides was not cut correct. So there is a gap that lets water run in over the dash and unto your leg. I asked the dealer about it. He call Honda and they sent him 2 new rubber seals at NO CHARGE, Now I can cut and install them the correct way.
BadDog
31
15
I have the same windshield and had the same issue. Fortunately mine was still hanging on when I noticed it.
63,408
Did you do anything to insure it would not blow off again?
BadDog
31
15
Not yet. Just noticed it Monday after trailering it home. I popped it back on and was planning on finding a sealant but I'm not sure whats best to use.
