Multi 10 Amazon Christmas Gift Ideas for any budget!
67,230
Christmas ribbons 1 1
Alright, it's that time of the year again and where hunting the perfect gift for someone or for yourself can be challenging. To help, we have compiled a short list of 10 popular items found on Amazon that fits anyone's budget. Also, If you found something on Amazon that interest you please post an image and link for everyone to check out!
*Christmas Hint
Once you found something you like, just leave it up on the computer for Santa to see.
Happy Holidays and Merry CHRISTmas.
$10-$15
USB Charging Rocker --> Amazon.com: USB Charging Rocker: Electronics
61uyDfat8qL SL1001
  • Compatible with popular mobile devices USB 2.0, any device including digital cameras, PDAs, mobile phones and USB accessories.
  • Over-heated, over-current, over-charging protection, charging will be automatically stop when battery is full, easy to use and install.
  • As a replacement or extra 12V-30V DC dual USB charger in vehicle.
  • Great for the boats or outdoor use due to waterproof cover.
BUY HERE --> Amazon.com: USB Charging Rocker: Electronics
$30-55
Blue Sea Systems Fuse Blocks --> http://amzn.to/2eQOQZY
81XeIa6B2KL SL1500
  • Positive distribution bus with #10-32 stud
  • Can be used for 24-hour circuits
  • Cover satisfies ABYC/USCG requirements for insulation, incorporates an easy to open push button latch providing easy access to fuses, storage for two spare fuses, and label recesses that accept Blue Sea Systems Small Format Labels for circuit identification
  • Accepts ring or spade type terminals
  • Accepts ATO/ATC fast acting blade fuses - fuses sold separately
BUY HERE --> http://amzn.to/2eQOQZY
$40-$50
SureCan - Gas Can --> http://amzn.to/2eQNPB3
61JJ 6PPjDL SL1000
  • 2.2 Gallon or 5 Gallon
  • Patented thumb trigger that controls the flow of Fuel
  • Long, flexible, rotating nozzle
  • Dispenses from the bottom eliminating tipping to pour
  • Self-venting for a Quick smooth flow without glugging
  • Spill-Proof, child-proof design
BUY HERE --> http://amzn.to/2eQNPB3
$73
Pro Armor A040810 Complete Fire Extinguisher Kit --> http://amzn.to/2g3TxWg
81255nnkIOL SL1500
  • Pro Armor Complete Kit.
  • Mounts to most any size UTV bar.
  • Weight 8 pounds.
  • Fast removal during emergencies.
BUY HERE --> http://amzn.to/2g3TxWg
$110
True UTV-SBI-15CM UTV Dual Battery Connect & Monitor Kit - http://amzn.to/2eQQCKI
81N8XWgUczL SL1500
  • 1- True UTV-SBI-15 Isolator with silicon insulators and 3M Dual Lock™ fastner
  • 2- 36mm led volt meter 1-blue, 1-green (requires 29mm mounting hole)
  • 1 ea- True 12" sealed Red and Black Cables with 6mm lugs
  • 1- True Volt Meter duplex pair 8 ft wire 18ga with connectors
  • 1- True 18" sealed Red Cable with one 6mm lugs
BUY HERE --> http://amzn.to/2eQQCKI
$150
Odyssey PC925L Drycell Battery --> http://amzn.to/2fNI7Rh
71UWi34ClRL SL1500
  • Voltage-12
  • Capacity-28 Ah
  • CCA-380 CA-925 RC-52
  • Termination-SAE
  • Warranty 3 Year (processed through our facility)
BUY HERE --> http://amzn.to/2fNI7Rh
$225-$300
SuperWinch Terra45s --> http://amzn.to/2fPgGu5
81zBW6kBTYL SL1500
  • High efficiency, low amp draw, sealed 1.6 hp permanent magnet motor featuring mechanical load holding and dynamic brake
  • 55' of 1/4" synthetic rope, drum designed for use with synthetic rope and ergonomic cam action freespooling clutch
  • All steel planetary gear twice as wide as those used by the competition and utilizing machined-in, oil pocket bronze bearings
  • Circuit breaker protected and weather sealed solenoid contact
  • Anodized aluminum hawse, heavy duty latched hook with thimble and limited lifetime warranty
BUY HERE --> http://amzn.to/2fPgGu5
$300-$447
Go Pro Hero 5 --> http://amzn.to/2eQHAgG
61B3h4thkvL SL1500
  • Stunning 4K video and 12MP photos in Single, Burst and Time Lapse modes.
  • Durable by design, HERO5 Black is waterproof to 33ft (10m) without a housing
  • Additional GoPro HERO5 Black Features + Benefits below on item page.
  • Preview and playback your shots, change settings and trim your footage, all on your GoPro.
BUY HERE --> http://amzn.to/2eQHAgG
$550
Pioneer 1000 Radio Stereo System --> http://amzn.to/2fE6SAd
91JIEM3EaTL SL1500
  • USB, SD, Bluetooth, am/fm Radio, and AUX, NO CD PLAYER
  • Mounting & Wiring Hardware all included!!
  • Easy to Install and Ready to use!!
  • 4-5.25" Boss Marine speakers!!
BUY NOW --> http://amzn.to/2fE6SAd
$599
EZ Steer Power Steering Kit for Pioneer 700 --> http://amzn.to/2eV7140
51dZZaOvKYL
  • Fits 2014-15 Honda Pioneer 700
  • Reduces steering effort
  • Virtually eliminates bump steer
  • Has sealed input and output shaft
  • Watertight control box and connectors
BUY NOW --> http://amzn.to/2eV7140
nbomar
nbomar
4,416
17,854
Springdale, AR
I'll let you know how it works when mine comes.. Going to take pictures or do a video
I follow surecan on instagram. They definitely abuse those cans in their ads and they hold up well. I hate any can that has the stupid EPA stuff in it. The nozzles suck and they break very easily usually.
Reactions: drfubar
LandPioneer
LandPioneer
929
2,417
Lebanon TN
Definitely some goodies I could use on that list!
nbomar
nbomar
4,416
17,854
Springdale, AR
Ok so I was just told I have like $200-300 to spend on myself for xmas. Ideas guys? I was thinking maybe rock lights and whips? I don't ride very much at night right now though...
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
First of all, does 2-300 really mean 2-300?
In my life when the Mrs says 2-300 I interpret that to mean 300-350.
nbomar
nbomar
4,416
17,854
Springdale, AR
I like the way you think. This is the mother in law. I'm not sure she does though. Ha ahaha
Reactions: Tflynn
Tflynn
Tflynn
Not a liberal
2,501
3,833
Northern California
Here are some things I'd be looking at. I own all of this stuff and like it more than I thought I would, in no particular order-
1. Spare wheel and tire
2. Battery powered jump start packing
3. Rotopax gas can
4. USB charger/voltage meter (already mentioned in OP)
5. Ram mount for phone (or pistol, cup holder, tablet, etc)
6. Led cubes (4 pack on Amazon for $30!)
7. Any kind of recovery gear. Straps shackles etc.
8. RTIC cooler
