P1000 1000-3 honda rear panel with non honda roof
ODAMO
ODAMO
1,286
3,461
Ohio
Is anyone running an oem honda rear panel with a non honda roof?
If so were any modifications needed?
slowdryrider
slowdryrider
574
784
Canada
I'm not sure of what you will need to do. I can tell you that the rear panel does touch the underside of the Honda roof sealing against it with automotive style weather striping. The Honda roof sits up higher then the roll bar so not sure how or where your roof will sit against the roll bar or higher up. I'm sure if your roof sits flat on top of the roll bar you could possibly cut the top of the back panel to match your roof .
Reactions: ODAMO
