P1000 1000-5 deluxe new tires w/factory wheels?
N
nelson1033
7
Running out my factory wheels on my 2019 1000-5 Deluxe. When I buy me new tires I would like to go the same size all around. Is that possible using stock wheels? The stock wheels are the same size right? Will I need spacers in the back? I am thinking 28x10 carnivores or terrabites. Never done much with wheels or tires. Looking to keep things simple but get some good universal tires that can take some miles.
1Ktrailrider
1Ktrailrider
183
282
Pennsylvania
If your running factory rims and same size tires on all 4 corners you cant rotate front to back so it kind of defeats the purpose of all the same size tires. Factory front rims are narrow and the rears are wider. You won't need wheel spacers for anything. I've seen it done and it looks fine but the front tire bulges out of the rim a little more. I did larger tires on factory wheels and didn't see any added benefit to the wider tires up front so I did 29x9 and 29x11.
Reactions: nelson1033
Russ989
Russ989
22,645
147,291
I believe @Hondasxs is still running the factory wheels on his 1000-5, maybe he will chime in.
68,434
I have 30x10 terribites on stock wheels. Had 28x10's before that.
To me, it looked like the rear set in more than the front afterwards so i added spacers.
I think you should add 1" front and 1.5" rear spacers and it will sit just right. From @RB3offroad
If they made just 1/2" spacers I'd say do that.
