P1000 1000 start up
BBLASER
159
277
Phoenix
So I have noticed over the last few times taking mmy 1000-5 for a spin that if I turn the key all in one motion to start it, it will start pretty sluggish for a second or two. If I turn the key half way for one second and let the fuel pump start up, it fires up much smoother. Anyone else's do this? I think it might be normal, but I never noticed it in the past.
farmtimpioneer
farmtimpioneer
Wise Men Still Seek "Him"
549
2,079
Brookville Ohio
It is normal mine does the same thing nothing to be concerned about, I have always had a habit of turning on the ignition for a couple seconds before starting anyway it comes from driving a Diesel, not a bad practice on gas either just gives pump time to build pressure,,,,,
Russ989
Russ989
22,642
147,257
Mine does it every now and then. Nothing to worry about.
BBLASER
159
277
Phoenix
Thanks guys. I figured it was normal, but sort of threw me a little. Thanks
Reactions: Russ989
0860silverado
956
1,845
louisiana
Yeah, I pause in the "run" position until I see my dash normalize and all the clicking/priming stops and then I fire her off. It gives the ECU a chance to sense engine temperature, air temperature, air pressure etc so it can inject an optimal air/fuel ratio along with proper ignition timing.
Reactions: Mudwing and Russ989
