P1000 1000 stereo and lights
P
PoolGuy444
11
17
I really like the jbl. I don't have much to compare it to. But I had the same setup on my 700. Only thing I didn't like then was it didn't display time. The 1000 has a clock so no more worries. About the mounting brackets. I think I just searched Amazon for 1 3/4" roll bar clamps and there were some that are identical to Hondas. If I remember right they were around 10 bucks each. They fit tight but they do fit.
P
PoolGuy444
11
17
Oh and I didn't relocate the sticker. I stuck it to the wall in my shop. It has an aluminum backing but I still bent it all up taking it off. It may be illegal, but not sure who would actually enforce that.
Reactions: pct
dale5740
dale5740
886
417
mt airy md
well if the HEAT comes down on u please let us know!! sorry can't help myself just joking around :p
Reactions: pct
TractorMan
TractorMan
98
159
Looks great. I was wondering how everyone is making the letters on their shifters white. Did yours come like that or did you do that yourself? If you did then I would like to know how. I would like to do that to mine. It is hard to see the black on black in my machine. Thanks
Reactions: pct
A
AK_Centurion
271
330
Eagle River, AK
White paint pen is what I used.
Reactions: pct
TractorMan
TractorMan
98
159
Is there any special paint to use or preparation to do in order to get the paint to adhere to the plastic? Usually if you paint plastic the paint will rub off rather easy. I know there are certain ways to make the paint adhere better because I have heard others mention it. Guess I will have to look into it deeper now because I would like to do that.
A
AK_Centurion
271
330
Eagle River, AK
I didn't do anything special other that a wipe down with alcohol. Used a UNI paint brand pen. Starting to show wear though. Might want to scuff up the lettering first, 400 grit sandpaper?
Reactions: pct
TractorMan
TractorMan
98
159
Good idea thanks. I will do some digging to see if I can find the best way to do it. I really like the looks of yours.
Reactions: pct
Go to an automotive paint supply company and ask for adhesion promoter. Heat the area up very well with a blow dryer (to release the plastic mold agent that stays inside the plastic) to around 160-180 (touchable but hot) degrees for about 10 minutes wipe with alcohol only on letters to make sure it doesn't chemical burn the surrounding area and apply while still hot. Apply promoter. Try to use a two part paint like a urethane (nail polish will work pretty good as well and easier)immediately following. Plastic sucks I've dealt with it for years. That is the best you can get.
Reactions: Cal and pct
TractorMan
TractorMan
98
159
Thank You for the info.
dillonhart
37
26
shreveport, LA
So I am new to the side by side world. Just purchased a 1000-5 deluxe.
I am wanting to start wiring lights and put a switch panel in. Is it possible to just peel the warning label up and get started?
thanks
Reactions: pct
Eltobgi
Eltobgi
4,599
15,187
North Dakota
thanks
Oh yes anything is possible! Congratulations!
Reactions: sharp
sharp
sharp
3,757
14,955
Tennessee
thanks
The warning label is a thin metal find a smell drill bit that will fit inside the rivet hole drill into it then pop it right off!
