I'm just about to do my initial service on The Family Rig. What oil have you had the most success with in helping it run quieter and shift as smooth as possible? Also, any other things I should do now to help?
im trying to uoad a video from my phone but the .mov is not working. Does anyone know what format they need to be in?
Put 10 30 Honda oil works great I got over 2000 miles with no problemsI'm just about to do my initial service on The Family Rig. What oil have you had the most success with in helping it run quieter and shift as smooth as possible? Also, any other things I should do now to help?
I think what you're referring too for fluid change and noise reduction is in the gear oil weight and I think many are running a heavier synthetic there. The mechanic told me to run conventional motor oil after the first oil change because it has better detergents in it.. that maybe BS but it was cheaper and he had a convincing argument.. he said at the second oil change if I wanted synthetic, then to go for it. I wouldn't change the motor oil weight from factory though.
Make sure it has the JASO rating from the owners manual.
Do not use one with friction modifiers. You have a wet clutch.
Want to make sure the rings are set before swapping to synthetic. A lot depends on how you drive it. If you're real aggressive 1st oil change should be good but probably best to wait till the 2nd or 3rd. They also have the blended hp4 that I'll probably change to on the next change. Currently using the hp4s.
I didn't see a JASO rating on that. Are you sure its ok for wet clutch applications?I have been using mobile 1 European car formula 0 W 40 for over 4000 miles. I use it year round. It complies with Honda's recommend service oil.
In what?I have been using mobile 1 European car formula 0 W 40 for over 4000 miles. I use it year round. It complies with Honda's recommend service oil.
