P1000 11:1 Hess pistons timing or not ?
DennyChapman
DennyChapman
68
202
Statesboro Ga.
I just installed the 11:1 Hess pistons in my p1000. I also have the HMF XL exhaust that will be in any day now. I also have the reduction boss IGR that will be in end of month. I already have the COPS tune installed. My question is, do i need to adjust the timing because of the higher compression, because stock is 10:1 and it seems id have to add 3-5 degrees of timing. ? So I can’t get intouch with ANYONE at cops ( COMPLETE OFF-ROAD POWERSPORTS) To help me out on this.
i talked to a HMF tech and he says the exhaust will definitively need tuned due to the higher compression, any advice or direction would be great. Thanks
NTCPrezJB
NTCPrezJB
Retiring Member
108,798
959,715
Hidden
🤔Strange…I’ve heard so many stories about their customer service
wyldeman
wyldeman
17
38
Fort Wayne, IN
When did you obtain the tune from COPS? Was it when they were using Dynojet or was it after they burned that bridge and switched to the Alien[something] unit? Whether you do or don't have the PV-3 Dynojet unit... I would highly recommend Scott at Florida Cracker Performance.
Just a suggestion, I've had my experience with Zachary. Paid him $1,300 and 6months of a run around until he just started ignoring my calls/texts. May want to leave well enough alone
wyldeman
wyldeman
17
38
Fort Wayne, IN
I got the tune last year when it was still Dino jet. I have the pv3
Scott does a great job. Not sure how intensive your modifications are, but he can get you taken care of pretty quickly and provide immediate delivery of the tunes you are looking for. In fact, he has some of the same category options as COPS did, (Trail, Mud, Sand, etc.). He may ask you to send your existing to tailor it or suggest a complete new build...
[email protected]
www.floridacrackerperformance.com
(I found a phone number somewhere but can't place it. But using the online chat option on his web page works well too)
Good luck!
snuffnwhisky
snuffnwhisky
Village Idiot
3,308
18,181
Cullman, AL
  2. Other Brand
Generally the same or less timing when going up on compression. You should run leaner when in open loop. Unless someone has tuned with those same parts and has a tune, you would be best having it custom tuned on a dyno. Should be about a 3-5% change in fuel needed.
DennyChapman
DennyChapman
68
202
Statesboro Ga.
Should I use the cops tune when on the dyno and being tuned ? Or should I set it back to factory
