P1000 16 Pioneer 1000
MikesSXS16
5
7
Roscommon Mi
I am having issues with my Pioneer not going into gear. the lever moves, the lever on the trans moves. Sometimes it grabs for a second
then it acts like it slips out of gear.
105,915
Welcome fellow Michigander!
I have a cabin in South Otsego Co
Almost to Roscommon.
Yeah check out that vidga from @Mark in Northern Iowa posted.
Likewise, do an into and post some pics of your ride! Its Rule #4
Pics Or It Didnt Happen!
MikesSXS16
5
7
Roscommon Mi
Howdy and welcome from Northern Iowa.
If you are talking about low, first try and adjust your shift linkage.
Here is a YouTube to show you how.
Do an introduction and post up some pics of your ride. 👍
Have a good day
I adjusted the transfer case cables on the driver rear. I was trying to pull a friend out of a snow bank and I put it in reverse and it sounded like a drive shaft flopping around. I have it up on my hoist, it acts like it wants to engage then doesn't. I did a relearn program for the clutches. Stumped on what to look at. Voltage is 12.6.
slowdryrider
slowdryrider
563
756
Canada
Try this with the machine turned off . Shift your machine from Park to Reverse when you hear/ feel it click into gear where is your shift lever sitting . Is it sitting in the proper spot [slot] or is it in between slots and doesn't line up. Try each gear low ,high and see where the shift lever is actually sitting. The adjustment for the cable that shifts the sub trans is underneath the battery under the hood. Your cable may need adjusting if this is what your having happen. Keep us informed with what you find.
Reactions: Backwoods
DRZRon1
DRZRon1
852
2,743
need pics of your ride.......
were you pulling in low range. were you pulling or yanking, lol - were you getting a run at it?
12.6v while its idling?
you have traction when pulling or were u on snow as well?
will it move in;
reverse
low
high
guessing you can see the front driveshaft on the lift - it ok?
MikesSXS16
5
7
Roscommon Mi
will it move in;
reverse
low
high
I have it on my hoist in my barn. Everything is defrosted. I hit a snow drift before I got to my friend that was stuck. it sounds like it grabs and sometimes moves a couple inches than doe not engage all the way.
MikesSXS16
5
7
Roscommon Mi
Thanks for the reply. I am do back to work next week on tuesday. I am usually in Roscommon on sat evening until monday night.
