P700 2" super atv lift and commander shocks
DBD
DBD
67
141
Pennsylvania
Has anyone done the commander shocks swap combined with the super atv 2" lift? Already have the lift on with 28×10×12 tires. Planning on picking up a new set of commander shocks this week. As I understand they lift the machine at stock mounting angles, which are modified a bit by the nature of the superatv lift. Are there any concerns I should be aware of or tips to keep from extreme lift, and/or axle issues. Thanks in advance.
JimmyA
JimmyA
1,644
5,504
Northeast texas
I think that RB3 spacers would help to stay planted, plus make the rig more aggressive looking stance!
DBD
DBD
67
141
Pennsylvania
I did look at those, would probably make a set at work, I work in a cnc machine shop. But honestly I think my next step anyway would be 15% portals and 30's or 32's so that would give me a 6-8" wider stance and back to normal power like I had with all stock and 25's
AKChef
AKChef
5
14
Alaska
I have portals (Not installed) & 814 shocks (installed) forward arch arms from OutKast Fabworx (installed). I was wondering what else I would need to add before I complete the install of the portals? I took it out last weekend and broke both Front axles at the knuckle. This weekend I was going to install the portals and new axles. Do I need to lift the front differential? The axles broke because of the angle so I am assuming the portals will solve that.
DBD
DBD
67
141
Pennsylvania
Do you
DBD
DBD
67
141
Pennsylvania
Portals adjust for lift and gear ratio to compensate for bigger tires with a lift kit. Do you have a lift? Also what were you doing when the axles/universals snapped?
AKChef
AKChef
5
14
Alaska
I was stuck and put it in 4 diff lock when the axles snapped but I also should have waited to install the portals to have the better angle. Currently the only lift is the 814 shocks and the 29.5" Swamp Lites. I am installing 30" tires on 14" rims with the portals when I get back from hunting. Having to use the Foreman for the next few days.
I
ike775
48
116
yerington nevada
How are the portals working out?
