P1000 20 hour check
Mollie46
69
86
AZ
We purchsase our honda 1000 delux and off we went on vacation where we put 1500 miles on the Pioneer, I changed the oil and filters as required and changed the front and rear diffs also. Thsi work was done my myself due to no dealer close by. Will this have any effect if a waranty issue comes up? The unit runs great.
Reactions: TripleB
TripleB
TripleB
15,251
136,235
Caryville, Tennessee
It shouldn't. Keep some type of records where u bought the oil and filter and u should be fine.
SWB
SWB
2,013
7,074
South Central Arkansas
Believe valves were suppose to be checked also. Honestly they would probably want you to bring it in anyway. So there would not be any problems with warranty.
66,870
Honda says *only if needed on valves.
Meaning only if they are noisey.
99 out of 100 units do not need valves adjusted at all.
SWB
SWB
2,013
7,074
Okay. Sounds good. I went 20 hour. They recommended it. Told them I would service rest.
0860silverado
954
1,834
louisiana
Warranty does not require oil change being done at a dealer.
Correct. There is actually a law protecting customers' rights to perform services on their machines without fear of voiding their warranty, as long as that service is done properly and doesn't contribute to any failure. Also...they cannot deny a claim for something like a burnt engine because you added a bugbuster windshield. They CAN deny an engine claim if you disable the rev limiter and spin 'er up to 10,000 rpm.
Reactions: BigOL3
