P700 2014 700+4 Shifting Issue
P
philorr
6
Mexico
Dear Honda Tech,
I have '14 700+4 that has issues shifting up while underway. I can let off the gas and "trick it" to shift up. Going downhill seems to be better. In 4 wheel drive its worse especially in soft sand. 3rd gear is the worst gear that it has problems shifting into.
Oil Pressure is great both engine and transmission
Replaced TPS
Checked all other sensors
I am at a loss, help!
Thanks for even looking at this
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
any codes on dash?. if not try doing a reset take battery terms off for a few mins.
Sent from my E6910 using Tapatalk
P
philorr
6
Mexico
I will try that and look at grounding also
thanks
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
with good pressures only thing i could think would be power loss or its time for oil change. i try to do 1 a yr when i dont hit the mileage or hrs. kinda like how a vehicles has miles or months.
P
philorr
6
Mexico
New oil change with Honda oil. Pressure is good in engine and transmission. No power loss
Reactions: Backwoods
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
I will do this today
im at a loss. if you have full power but its not wanting to shift and its not slipping then its kinda pointing towards either your transmission controller what ever tells it to shift. or the shift selenoids are sticking.
P
philorr
6
Mexico
Yes, that's my last fix. After rebooting the ECU it's better but not perfect. My mechanic thinks I might need the valve body also because of the needle pins aren't acceptable and could be stuck
Reactions: Alan_Vander
