Farmer
Have an appointment to drop it off at the local Honda dealer to have the valves checked and see if that's the problem. If not, they're supposed to figure it out and fix it
The symptoms aren't the same so let's hope it's not another low mileage cam eater like mine and many others. Maybe bad spark that needs some gas to jump the arc? Another issue these had was a brittle plug cap. Basically, if you pulled it they broke the little part inside. I'd think it'd be more of an erratic or rough idle though.
