P700 2016 700 having issues with clutch or trans ???
Srchamberlin
34
61
hey guys I have a 2017 700
has around 600 miles, started having issues with trans slipping.
Changed oil and filter all Pam
went out on a ride did good for awhile , then was a little hard to start after taking a break. Started to go up a decent incline and blew a big puff of smoke and acted like it was looking power. Made it to top and came out of it but continued to act up rest of ride.
The next day I got it out to do some yard work and seemed like it was ok , but started slipping again. Barely made it back to garage ???
just changed oil and adjusted valves last time it did this thought that would help but didn't last.
Put new filter , oil, and plugs and air filter before we went riding .
any suggestions or help please
Srchamberlin
34
61
sorry all OEM parts and oil
Russ989
Russ989
22,588
146,743
What did the oil look like when you drained it? Are you having engine trouble and clutch trouble?
Srchamberlin
34
61
oil looked dirty
was smoking every time you hit gas then would go away so I changed it had a shop change plugs and adjust valves
then I changed air filter before I went riding did ok for about an hour then started same stuff as before
Srchamberlin
34
61
oil looked dirty
Srchamberlin
34
61
it seems like a power and trans issue acts like trans is slipping
Srchamberlin
34
61
is there any way to test clutch or transmission
Reactions: Russ989
Russ989
Russ989
22,588
146,743
There is a way to test the trans but you need special gauges to do it. You shouldn’t be seeing smoke from the exhaust, you may have a camshaft issue possibly, it’s just about the only weak link on the 700’s.
Reactions: Srchamberlin
Srchamberlin
34
61
where can I check transmission ??
with the right guages
Reactions: Russ989
Russ989
Russ989
22,588
146,743
Reactions: Farmer
Russ989
Russ989
22,588
146,743
You could try this to somewhat eliminate the transmission.
Transmission fail safe. How does it work.
Check your oil level as well, the 700 transmission is very touchy about how it operates in conjunction with the oil level. They like to run FULL! Follow this procedure below. Also, make sure that you have at least one bar on the temp gauge before moving the pioneer.
0A42A44D E8C5 45B3 8B83 4DB3FFE74435
Alan_Vander
Alan_Vander
1,547
2,750
rosepine,la
doesnt sound like a cam issue. cams usually progress slowly over time or just flat go out pretty quick depending on how you ride. sounds more like a ring or valve issue being your smoking. pull your spark plug and check it. can try a compression test as well. until you find out the issue with the motor the trans really wont feel right. my buddy put car oil in his 1 time. and went well over miles on change and now his clutches arent slipping but the trans doesnt want to shift at the correct time.
Farmer
Farmer
2,850
16,380
Southern MO
Sounds to me like you need to make a trip to the dealership for some diagnosing.... If it's been submerged and run with water..... they take several oil changes to get it all out, then you could have worn rings and bad compression. Low power could feel like a slipping trans. So could water in the torque converter if the oil wasn't changed multiple times after flooding. The torque converter uses engine oil so it's a pain to get it all flushed. You could search some flooded 700 posts to see what others have done.
Farmer
Farmer
2,850
16,380
Southern MO
Also, going in a completley different direction.... I know these things had issues with spark plug boots breaking every time they were touched. It got to the point that they say to plan on having replacement boots on hand in case you need to pull the plug for some reason. So, maybe bad spark. But that would probably be more of a sputter than a lack of power. The smoking makes me wonder though.
