P700 700 electrical issues
Rodger Dodger
Rodger Dodger
15
38
Florida
With the ignition off my 700 shows it is overheating and the engine light is flashing. It is doing this when I know it’s not hot. I can disconnect then reconnect the battery and it will run fine while showing normal water temp. Eventually it will do the same thing again. Anybody have a clue? Thanks in advance
DRZRon1
DRZRon1
1,451
4,433
PA
Ignition switch
Rodger Dodger
Rodger Dodger
15
38
Florida
Replaced ignition switch….same problem. Tracing grounds now but still scratching head
Slackjaw
Slackjaw
294
462
Durham NC
Air in cooling system maybe.
Burp / bleed.
43,587
I can't remember...but there is a situation wherein the dash stays on even with the key off. Dead or dying battery or something. @Hello_Darkness probably knows...
Get it to do it, the start pulling relays. When you find the one that kills it, try switching it with another (but keep track of it) and repeat, and if that fixes it, just need a new relay.
Could also be a short to voltage somewhere.
The flashing check engine light will also give you a code as a guide.
Doubt the grounds have anything to do with it. I can tell you from experience that loss of ground to the PCM in these things immediately shuts them down.
Reactions: Rodger Dodger
43,587
Here's a link to pulling codes...
Why not sticky this, moderators?
Hello_Darkness
Hello_Darkness
679
2,757
Just to the right of nowhere
This tends to bey the main relay sticking due to low voltage. But with his unit not having starting issues, atleast not stated, I don't know if that's what causing the relay to stick.
But I've seen it on new units that arrive with weak or almost dead batteries. Usually the symptoms are accompanied by a clicking ot buzzing noise in the relay/fuse box area
Reactions: DG Rider
Rodger Dodger
Rodger Dodger
15
38
Florida
Thanks for the suggestions….solved problem….bought a 1000.
Reactions: cloleson
NorthernJoe
NorthernJoe
386
1,491
Northern Ontario
Congratulations!
You solved more than one problem with that move! Now we can suggest a ton of mods and help you spend your money
first thing to do is check your toe in / toe out, the best cheapest mod is the cat delete
Similar threads
