P500 2016 P-500 No display
P
Phillig
SC
My 2016 P-500 will turn over but the display doesn’t light up nor does the fuel pump run. Everything was fine until I shut it down for the season about two months ago. It has a new battery. I’ve checked all the fuses except the main fuse. Any ideas what might be the problem? Thank you!
906UP
906UP
14,957
142,117
da Yoop
Check the main relay (or connection to it), it's in the battery box. If it's not coming on that will cause the ECM, dash, fuel pump, etc to not come on. Do you have a shop manual? Supporting members can download one
P
Phillig
SC
Thank you. Yes, I have the shop manual. I will check the relay.
