P500 2017 Pioneer downhill engine braking video
11,316
84,066
Steep downhill, engine braking in 2nd gear. First trail ride. Sweet! By the way, is a 2500 lb winch big enough? Already have one with wireless remote. Guess I could always use a snatch block if not.
If you had to buy one, I'd go bigger, just because, but sense you have one, I'd use it, you'll probably be fine, almost certainly with a snatch block. Normally steepness of hills isn't too discernible in pics and videos, but I can see the steepness in that so I know you were going down a fun one there!
KYhillbilly
KYhillbilly
548
1,647
Ashland, KY
1100 lb maching so 2500lb winch should be fine. If buying new I would go 3500 but if you have it use it until it breaks. I also like the wireless control, very handy.
I bought an aluminum snatch block and carabiner for climbing, weighs next to nothing and makes rigging a breeze.
I have stalled a 4500lb doubled with a snatch block. Took a second machine with another 4500lb doubled to get a 1700lb machine free from the thick clay.
Mud holds on to ya. It's not just rolling the machine you may have 5000lbs of mud that doesn't want to move in the way of the direction of pull.
Climbing gear is made for a short dynamic shock load. It's not engineered for a static pull. Steel is going to be your most economic option in that regard.
11,316
84,066
Tractor Supply and Harbour Freight have some inexpensive choices for a smaller snatch block. After years of winching with a FJ40, tree strap, extra shackles and a snatch block should be standard cargo.
IMG 3755
Reactions: ohanacreek
KYhillbilly
KYhillbilly
548
1,647
Ashland, KY
I am typically pulling up steep hills where traction is issue and not buried in mud, have a steel snatch block but aluminum rescue pulley has held up very well. Or using it to drag a deer out of a hollow.
Before I had my winch used my Honda Rancher with a 2000 lb winch to turn it back upright and pull it up a steep incline. Had to anchor Rancher to tree. Hydraulic locked up the P500 as it filled intake with oil when on its side. Once on flat ground got I cleaned out and drove it home.
If hard core riding where you know you will be using winch often I agree, go with steel. If for emergencies or the occasional winching the rescue pulley works great and minimal weight.
KYhillbilly
KYhillbilly
548
1,647
Ashland, KY
strap, rope, 2 aluminum rescue pulleys and 3 carabiners in P500. steel snatch block, 2 straps, 3 d rings in 4Runner.
hope to only use P500 supplies for dragging and hanging deer, and occasional ugh oh getting stuck.
11,316
84,066
KYhillbilly, what kind of box on your machine? How amounted? picture?
KYhillbilly
KYhillbilly
548
1,647
Ashland, KY
it is an aluminum Yamaha golf cart bed. I mounted it by drilling holes on each side of the rack flat bars then put a metal tab under the flat rack bar and bolted. Covered metal bar or tab and rack with foam weatherstripping to prevent vibration and scratching of the rack. Tried to get one of the plastic beds that goes on a landmaster UTV but shipping was more than the bed.
Reactions: Mudder
Little_g
Little_g
404
660
Parker, AZ
Have you used the automatic going down that same hill?
